Old 11-29-2021, 10:36 PM   #1
jdpalmer
jdpalmer's Avatar
Default head gasket
ok ideas on head gasket, on grafite do you spray or don't spray sealer? is the turned over up or down?
Jimmy Palmer
jdpalmer is offline   Reply With Quote
Old 11-29-2021, 11:24 PM   #2
Gary WA
Gary WA's Avatar
Default Re: head gasket
no spray! should say on gasket, Coppers all i use-with spray
www.whidbeymodelaclub.com
Old 11-30-2021, 03:01 AM   #3
mercman from oz
mercman from oz's Avatar
Nice collection of Model A Fords, Gary
Old 11-30-2021, 09:36 AM   #4
nkaminar
nkaminar's Avatar
I have used a variety of gaskets with and without spray. The best results so far has been with the Best brand graphite gasket with spray. See https://www.snydersantiqueauto.com/p...d=979899&cat=0. It is important to have very clean surfaces that are flat and to follow the torque sequence and re-torque several times and then once a year. I filled any pits with JB weld and used 400 grit paper wrapped around a flat file to smooth after it was cured.
Old 11-30-2021, 10:25 AM   #5
katy
katy's Avatar
Should the head nut's thread be oiled? Or not?
Old 11-30-2021, 11:12 AM   #6
JD 1931
JD 1931's Avatar
used the modern style years ago that Mike's has, sealed great with no problems, needs no sealant...Mike's affordable in Georgia, good guy.
JD 1931 is offline   Reply With Quote
Old 11-30-2021, 02:00 PM   #7
nkaminar
nkaminar's Avatar
I used anti seize. It helps when it comes time to remove the nuts. It also provides a little lubrication.
Old 11-30-2021, 02:52 PM   #8
Synchro909
Synchro909's Avatar
I only use the graphite gaskets with sealer and NEVER those ones with the silicone lines. Once was enough for those.
Old 11-30-2021, 06:26 PM   #9
Flathead
Flathead's Avatar
OK....I used one of those silicone printed gaskets a few years ago along with a 5.5 head. Still on the car with no problems and yes I do drive it often. I did do a meticulous installation and followed the instructions to the letter. With any gasket proper re-torque is critical.
Flathead is offline   Reply With Quote
Old 12-01-2021, 11:12 AM   #10
katy
katy's Avatar
Many years ago, when I didn't know any better, we used the copper clad head gaskets, no sealer, no torque wrench, just tightened them down really good and no problems.
Old 12-01-2021, 04:15 PM   #11
Ivan in southeast va.
Ivan in southeast va.'s Avatar
Copper gasket with spray and lots of re-torquing!
Ivan in southeast va. is offline   Reply With Quote
