Old 03-23-2021, 05:17 PM   #1
Gary Tosel
Gary Tosel's Avatar
Default 36 Ford Stock Engine Questions
The water pumps have grease fittings. What type of grease should be used?
Stock 18mm spark plugs are now Champion. What is the best replacement spark plug?
Gary Tosel is offline   Reply With Quote
Old 03-23-2021, 05:24 PM   #2
Lawson Cox
Lawson Cox's Avatar
Default Re: 36 Ford Stock Engine Questions
Water pump grease. Fords run best on Champion plugs.
Old 03-23-2021, 05:33 PM   #3
V8COOPMAN
V8COOPMAN's Avatar
Maybe 50 years ago they did. I wouldn't put a FREE "Champ" in my lawn mower today! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 03-23-2021, 05:44 PM   #4
tubman
tubman's Avatar
I had to look a while but I finally found the proper reach extended tip Champion plugs to use in the Edmunds heads on my 8BA. They have performed flawlessly.
When I got them and went to install them, I found they they were made in France.
Perhaps the jury is still out.
Old 03-23-2021, 05:54 PM   #5
KiWinUS
KiWinUS's Avatar
I use Champion UD16 in my stock 36. Never an issue & look amazing every time I check them.
KiWinUS is online now   Reply With Quote
Old 03-23-2021, 06:09 PM   #6
V8COOPMAN
V8COOPMAN's Avatar
I WAS a Champ advocate, and remember religiously running Champ UJ-8s and UJ-6s in several performance-type small block street Chevies I built during the last half of the '60s/early '70s. Around '71 or so, it seemed like all of a sudden, I couldn't keep a Champ going for nothin', no matter what I did. So, 'we' parted ways ever since! DD
T5 W/TORQUE TUBE
Old 03-25-2021, 03:42 PM   #7
Gary Tosel
Gary Tosel's Avatar
Thank you all for your responses. Found replacement NGK plugs and they solved the starting problems.
Where to get the proper water pump grease is still a question.
Old 03-26-2021, 09:07 AM   #8
1931 flamingo
1931 flamingo's Avatar
Check out Bratton's or Snyder's. They're Model A people but A's used w/pump grease. Readily available from either one.
Paul in CT
