Old 03-12-2021, 06:39 AM   #1
Phil Gillespie
Phil Gillespie's Avatar
Default 69a Stroker Engine Rebuild Completed
Last year purchased a 69a Stroker Engine good gear in it sadly the block was not water tight and also cracked in way of c/shaft through to camshaft.
Was somewhat screwed over.
However life goes on and greatly assisted by Brian Billing with the supply of a good 69a block the engine was rebuilt again correctly and just finished the other day. First test run after a 24 hrs static water test she fired right up and is a great engine.
Scat gear with Ross pistons 3 5/16" plus 30 thou with 4 1/8" stroke.
1CM camshaft, Edelbrock inlet manifold and heads, 390 Holey carb with vaccum secondaries, MSD distribuotr with mechanical and vaccum advance.
The final hurdle was sourcing a new ring set. Nil present supplies of Grant or Hastings rings till May/June.
Had a set made locally in Christchurch by Cliff Bond. Been a long process but in the end with that first start up all the bad times are history.
Always extremely grateful for kind assistance and advice recieved here.
Even my wife assisted with the cross check for TDC of No1 for fitting distributor.
Phil NZ
Phil Gillespie is offline   Reply With Quote
Old 03-12-2021, 07:13 AM   #2
corvette8n
corvette8n's Avatar
Default Re: 69a Stroker Engine Rebuild Completed
Glad it finally worked out for you, great looking motor.
Old 03-12-2021, 07:16 AM   #3
KiWinUS
KiWinUS's Avatar
Nice Phil. Great work. Should be a stump puller.
Old 03-12-2021, 09:27 AM   #4
flatford8
flatford8's Avatar
Nice!!...... what vehicle are you putting it in?...... Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver
Old 03-12-2021, 11:11 AM   #5
Phil Gillespie
It was to go in a 46 Merc Coupe. But with the screw up ended up rebuilding original engine out to 3 5/16" by 3 3/4" stroke. This goes real well.
So this Stroker Engine is a " Spare".
Phil NZ
Old 03-12-2021, 11:17 AM   #6
Phil Gillespie
Think the MSD distributor is a Chev type been adapted. Its just a one wire hook up with nil external coil. So if fitted to a flathead car would need to be recurved for Ford Flathead running, springs and stops etc.
Also should the vaccum take off for the distributor be above or below carb throttle plates?
Thanks Phil NZ
Old 03-12-2021, 11:34 AM   #7
JSeery
JSeery's Avatar
I would think below, as in manifold prrssure.
Old 03-12-2021, 04:12 PM   #8
Lawrie
Lawrie's Avatar
That is one strong looking engine stand.
Brian is a nice helpful person ,a great asset to out hobby
Lawrie
Lawrie is offline   Reply With Quote
Old 03-12-2021, 04:56 PM   #9
Ziggster
That’s a beauty!
Ziggster is offline   Reply With Quote
