Old 08-29-2020, 08:00 PM   #1
dlfrisch
dlfrisch's Avatar
Default Bolt / Nut tightening torques
I’m still looking for a list of nut/bolt tightening torques for my A. One associate said Less Andrews has a page, but must be a different issue than mine.
[email protected]
dlfrisch is offline   Reply With Quote
Old 08-29-2020, 09:39 PM   #2
shew01
shew01's Avatar
Default Re: Bolt / Nut tightening torques
[email protected]
If I recall correctly, Volume 1 has torque values on card stock on the last couple of pages in the book.
EDIT:
I was mistaken. The Specifiction Card at the end of Les Andrews Volume 1 does not contain torque values. By the way, you can search for "important errors contained in the les andrews books" on Google, and you will find a VFF link which attempts to document the Les Andrews torque value errors that are scattered across Volume 1.
shew01 is offline   Reply With Quote
Old 08-29-2020, 10:30 PM   #3
30 Closed Cab PU
Be aware the Les recommended torque for oil pan bolts is way off, too much torque. If you torque to his listed , the gasket will squish out and wreck the gasket.
30 Closed Cab PU is offline   Reply With Quote
Old 08-29-2020, 10:31 PM   #4
30 Closed Cab PU
Also, torque on manifolds are high, should be 30- 35 lbs.
Old 08-30-2020, 06:32 AM   #5
shew01
shew01's Avatar
I corrected post #2 above.
I think this link may have what you are looking for, but the site is down at the moment, which is odd. That site normally is always up.
https://www.brattons.com/specifications.html
Here is a similar link from Mac's Auto Parts, but the Ford Barn site does not launch the Mac's link correctly, at least for me. I have enclosed the URL in double quotes so that the full URL will display, you can cut and paste (or manually type) the URL into a browser window, and the link should work. You can search for the word "torque" on the Mac's web page.
"https://www.macsautoparts.com/ford_model_a/model-a-specs/"
Old 08-30-2020, 07:04 AM   #6
shew01
shew01's Avatar
The Bratton's site is back up. Search for "torque" on the page.
Try https://www.brattons.com/specifications.html
Old 08-30-2020, 09:24 AM   #7
goodcar
Ditto
goodcar is offline   Reply With Quote
Old 08-31-2020, 06:49 PM   #8
dlfrisch
dlfrisch's Avatar
Thanks shew01 - just what I was looking for. My project is on a little delay.....I had an emergency heart (pace maker) installed. My wife won’t let me go into the garage.
Old 08-31-2020, 07:39 PM   #9
shew01
shew01's Avatar
That sounds like you are married to a good woman. :-)
