Old 06-17-2016, 09:57 PM   #1
fordman
Default '40 coupe - column directional signals
I am adding directional signals with switch on the steering column. It has seven locations, parking lights, taillights, etc
Does the positive - ground cause problem?
comments ?
thank you,
fordman
fordman is offline   Reply With Quote
Old 06-18-2016, 05:42 AM   #2
adileo
adileo's Avatar
Default Re: '40 coupe - column directional signals
On my 6 volt 39, I tied into existing (parking lights in front - tail/brake in rear) lights, with seven wire switch. Positive ground did not matter. Make sure you get right flasher.
adileo is offline   Reply With Quote
Old 06-18-2016, 09:09 AM   #3
Lawson Cox
Lawson Cox's Avatar
Install a beeper to remind you signals are on, unless it is self cancelling. Small one (1/2 inch is plenty big)
20 gauge wire is plenty big. Don't waste money on larger wire.
