Old 02-22-2014, 09:13 AM   #21
CT AV8
CT AV8's Avatar
Default Re: Good Lookin Flatty
Originally Posted by Brendan View Post
they should not make those things! I went on a maiden voyage in my friends 35 pick up with a fresh motor. their was a bad vibration about 45 to 50 mph. we though something was very wrong. drove back to his shop and I dropped the fan belt and the vibration went away. took off the fan and put the fan belt back on and everything is good. he is going to take off the alternator and put a generator back on
You have to use a small diameter light weight aluminum or plastic fan, preferably 6 blades, and it will work fine. I've run mine over 4 years with no vibration or problems. I know the purists may not agree with this approach, but it's more appealing than an electric fan in my opinion.
CT AV8 is offline   Reply With Quote
Old 02-22-2014, 09:19 AM   #22
G.M.
That's the type of fan required to cool these engines. That impresses me more than the rest of the non necessary parts. G.M.
www.fordcollector.com
Old 02-22-2014, 09:29 AM   #23
Ken Arms
Ken Arms's Avatar
Flat v8, where did you send your generator? Ken
Ken Arms is offline   Reply With Quote
Old 02-22-2014, 09:32 AM   #24
felix37
felix37's Avatar
I love it! and the Alt. is just fine! I run one too, and as I'm driving across country I can pick one up anywhere!
felix37 is offline   Reply With Quote
Old 02-22-2014, 02:41 PM   #25
Pete from OZ
Pete from OZ's Avatar
Hi Fellas,
Thanks very much for your comments and concerns.I will pass them on.
36tbird -Pete, what is the story on the harmonic balancer? I knew they were available for 8BAs but that is the first one I've seen on a 59A.
I believe he has done a little machining and mounted it backwards. I will let you know.This is Tim,s first Flatty build
Here is a picture of it sitting in the Chassis. It has a Toyota Supra 5 Speed adapted. Open drive , 36 Banjo. 40 Juice brakes,VH 44 brake booster. Buick Drums. Headers are from Flat Attack here in OZ.
Pete from OZ
Pete from OZ is offline   Reply With Quote
Old 02-22-2014, 02:52 PM   #26
FlatheadTed
FlatheadTed's Avatar
Yes you can use a fun projects regulator .
Originally Posted by john in illinois View Post
Ken I am going to use 12V generator field coils and a NOS 12V regulator. I have a 39, I think, generator and fan.
I have read that you can use a 6V generator for 12V without changing the fields.
John
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 02-22-2014, 03:22 PM   #27
G.M.
You can but they need a smaller pulley which don't work with a alt. mounted fan at idle. Put in 24 volt stator and you can use a stock Ford pulley and it will charge at a slow idle. The stator is less than $25.00 Sorry but didn't see you started talking
generator but I will leave it posted as general information anyway. G.M.
Old 02-23-2014, 01:00 AM   #28
Rollingmenace
nice looking motor.. any info on the air scoops on the top of those strombergs I knida like them
Rollingmenace is offline   Reply With Quote
Old 02-23-2014, 02:33 AM   #29
thirt4
thirt4's Avatar
I was told once that there is an outfit that makes an alternator inside the old style generator case.
Perhaps if that is true, it might be a consideration for keeping those with the purist eyes from catching on and still get the amps needed.
Just my thought...
Still a good looking engine...
thirt4 is offline   Reply With Quote
Old 02-23-2014, 08:56 AM   #30
flat-v8
flat-v8's Avatar
Ken, I honestly don't remember his name, he is in WA, he sells on Ebay, does great work! I think I have his business card, I'll let you know. Or you could just check local auto electric shops, ask if they can & will work on generators, That is a crap shoot!
flat-v8 is offline   Reply With Quote
