Old 02-24-2021, 11:49 PM   #1
vern hodgson
Default Upholstery question
Seems I read somewhere that no padding was installed in door panels originally. Yes or no?
vern hodgson is offline   Reply With Quote
Old 02-25-2021, 07:18 AM   #2
nkaminar
nkaminar's Avatar
Default Re: Upholstery question
I don't know but suspect not. I know that restorers would stuff newspaper in the doors to make them sound better. Nowadays the available sound dampening material would be better.
Old 02-25-2021, 08:35 AM   #3
31Tudor
31Tudor's Avatar
Vern,
Do you mean between the upholstery and the backing, or in the door for insulation? There is a little padding between the actual upholstery and the carboard backing. On the door panels and the side panels of the rear of a Tudor. The other panels do not have padding.
31Tudor is offline   Reply With Quote
Old 02-25-2021, 09:31 AM   #4
Bob Bidonde
Bob Bidonde's Avatar
I have never found any padding on the doors or any of the side panels in Model A's. The interiors I have installed have no padding in the door panels.
Bob Bidonde
Old 02-25-2021, 09:49 AM   #5
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Vern, you gotta help out a little more. What bodystyle? Tell us which bodystyle and I probably can give you the part number for the wadding (-correct nomenclature for "padding") on whatever panel you are referring to.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 02-25-2021, 11:14 AM   #6
vern hodgson
That would be between the cardboard panel and the upholstery. The door bezel seems to not allow any space for padding and even installing over fabric would be a tight fit
Old 02-25-2021, 11:16 AM   #7
vern hodgson
So it’s just interior fabric against the door cardboard panel?
Old 02-25-2021, 11:17 AM   #8
vern hodgson
Oh yeah, a special coupe
Old 02-25-2021, 11:42 AM   #9
Gary Karr
Gary Karr's Avatar
On your Special Coupe, there should be a thin wadding of cotton material between the panel board and the fabric on door panels and the small lower side panels between the door and seat back. Most current upholstery kits will use a thin foam. I use a 1/4" cotton batting from a quilting shop.
Gary Karr is offline   Reply With Quote
Old 02-25-2021, 04:06 PM   #10
31slant
What do you guys use for panel board?
31slant is offline   Reply With Quote
Old 02-25-2021, 08:47 PM   #11
vern hodgson
I bought mine at Perfect Fit upholstery supply. Twenty dollars for two boards, enough to do both doors. Picked up at will call to save on shipping.
Old 02-26-2021, 12:12 PM   #12
Gary Karr
Gary Karr's Avatar
Your local upholstery supply stores should carry water resistant panel board.
