Old 07-07-2019, 01:24 AM   #21
aussie merc
aussie merc's Avatar
Default Re: Vapor Lock ...???
check the fuel line on the left side of the body if you have twin exhausts the left side is much hotter than standard as all factory exhausts where on the left .Try wrapping the fuel pipe in exhaust wrap or better still fit some type of shield to protect the metal line from the heat radiated from the exhaust
aussie merc is offline   Reply With Quote
