09-25-2015, 11:49 PM | #1 |
Model A engine, Model T frame, Model A axles.
Im gonna build a dirt racer or speedster style car out of some old junk. I got a T chassis for free from a club friend. I also have A axles and all the brake rods and pieces. When I loosely bolted the rear axle in the axle landed right in the hogs head. Aside from the width at the engine mounts is this a bit straight forward for a swap?
09-27-2015, 08:24 AM | #2 |
Re: Model A engine, Model T frame, Model A axles.
I think you are on the wrong forum. Click here to get to the hot rod forums:
http://www.jalopyjournal.com/forum/
1910 Touring 1914 Touring 1915 Touring 1917 Torpedo Runabout |
09-27-2015, 02:14 PM | #3 |
If you can trade the t frame for an A frame all the parts should fit better, however if you wanted to use a T frame … i'm not 100% sure of how you'd fit them.
<Link> This is how we roll<Link> "I'm Convinced that no one really reads posts anymore; they just fabricate what they think the post says then ramble on about red herrings."--Bob Outcasts rules of old cars #1 Fun is imperative, mainstream is overrated #2 If they think it is impossible, prove them wrong #3 If the science says it impossible you are not being creative enough. #4 No shame in recreating something you never had #5 If it were not for the law & physics you would be unstoppable |
09-27-2015, 02:50 PM | #4 |
Likely possible with a lot of crafting. Model A engine would need A rear end, you could fab brakes to the front of the racer.
This hot rod done that way, says its barn original, but seems to be a later redo, appears as T frame, front cross member moved forward. Would need that as a Model A engine with stock front mounted water pump and fan would spear the Model T radiator as its too close in std. frame. http://bangshift.com/bangshiftapex/1...rs-past-pride/ |
09-28-2015, 12:21 AM | #5 |
Lots of A frames around, so no need to work with that limp noodle T frame.
10-02-2015, 12:37 PM | #6 |
