Old 04-12-2021, 12:37 PM   #1
JMFL36
JMFL36's Avatar
Default Fuel line check valve?
After turning off my '54 Mercury with mechanical fuel pump, gas slowing drains out of the glass bowl until it reaches the top level of the inlet port. Its an AC 4052 dual action pump - gas and vacuum. Is there supposed to be a check valve somewhere in the fuel supply line? I am running just a short length of rubber fuel line from the rigid line to the pump.
Document your car with CollectorCarCompanion
JMFL36 is offline   Reply With Quote
Old 04-12-2021, 01:16 PM   #2
dmsfrr
dmsfrr's Avatar
Default Re: Fuel line check valve?
How long does it take to drain down?
I believe the outlet valve in the fuel pump 'should' prevent this from happening. If there isn't a filter before the fuel pump it may have a small bit of debris stuck in it???
dmsfrr is offline   Reply With Quote
Old 04-12-2021, 01:29 PM   #3
JMFL36
JMFL36's Avatar
It takes less than a minute to drain down. The 2 check valves inside the fuel pump affect the gas inside the diaphragm chamber within the pump. In my case, gas is draining from the glass bowl back into the supply line, before the gas spills down the center column into the diaphragm chamber.
Old 04-12-2021, 04:30 PM   #4
CrownVic55
CrownVic55's Avatar
You may have a restriction in your vent line on the tank resulting in a vacuum condition which sucks the fuel back to tank. Try removing the gas cap as soon as you shut car off and see if it goes down then.
CrownVic55 is offline   Reply With Quote
Old 04-12-2021, 04:42 PM   #5
dmsfrr
dmsfrr's Avatar
JMFL36, Is your photo in the first post upside down, or right-side up?
If the inlet & outlet valves in the pump aren't sealing as well as they should the fuel in the filter and line up to the carburetor can drain down to something like the level of fuel in the tank.
If you get a whoosh of air moving into or out of the gas tank when you take the gas cap off, the tank vent isn't working. If there isn't a separate outside vent line, the vent may be a very small opening in the gas cap.
Old 04-12-2021, 05:11 PM   #6
scicala
scicala's Avatar
'54 Mercury's were different than other Y-Block fuel pumps. They have the glass bowl/filter on top, and the vacuum pump on the bottom.
I've seen the fuel in the bowl low before, but wasn't an issue in how the car ran. If it starts and runs good, I would say good enough.
Sal
Old 04-12-2021, 08:34 PM   #7
JMFL36
JMFL36's Avatar
Took CrownVic55's advice and loosened the non-vented gas cap, started the car, ran it for a bit, and shut it off. Bowl stayed full. I must have a restriction in the gas tank vent line. I'll throw it on the lift tomorrow and blow out the vent line. Will let everyone know how it goes.
Old 04-13-2021, 08:09 PM   #8
paul2748
paul2748's Avatar
If the 54 Merc's tans are the same as my 54 Ford, there is no vent line. 54's used a vented cap - that seems to be the problem. Just drill a 1/16 hole in the cap.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 04-14-2021, 02:55 AM   #9
KULTULZ
KULTULZ's Avatar
Post Re: Fuel line check valve?
The 54 MERC was externally vented and had a closed filler cap.
- WHY IS IT ... -
... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag?
WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
KULTULZ is offline   Reply With Quote
Old 04-14-2021, 09:53 AM   #10
dmsfrr
dmsfrr's Avatar
Looking at the diagram... does the 'top' end of the vent line connect into the upper part of the filler neck, or is it open to outside air with some sort of small fitting on it?
Old 04-14-2021, 11:29 AM   #11
CrownVic55
CrownVic55's Avatar
On my 55 Crown the vent line exits the body close beside the filler neck. Open to outside air. If car has sit for awhile, it may have spider web or dead insects in it.
Old 04-14-2021, 04:48 PM   #12
KULTULZ
KULTULZ's Avatar
Question Re: Fuel line check valve?
Ain't this something?
THE MERC shows the vent above the fuel filler in the rear body panel. The MPC shows the 55/56 FORD sedan vent tied into the tank filler tube. Both vehicles show non-vented filler cap.
Earlier thread on same vehicle - https://www.fordbarn.com/forum/showthread.php?t=294148
I bet them mud-dawbers love that vent opening ...
- WHY IS IT ... -
Last edited by KULTULZ; 04-14-2021 at 04:59 PM. Reason: CAN'T SEEM TO GET MY SH!AT TOGETHER
Old 04-26-2021, 06:55 PM   #13
JMFL36
JMFL36's Avatar
Finally got to work on the Mercury today. I traced the fuel line from the tank to the fuel pump and found a spot where the steel fuel line comes within an inch of the exhaust pipe. (My '54 has dual exhaust so does not have the front crossover pipe like most Ford and Mercury cars of that year.)
After the car heats up the steel fuel line gets very hot in this spot and boils the gas before it gets to the fuel pump. This causes the sediment bowl to fill up with bubbles and eventually starve the pump (and car) of fuel.
Today I encased the fuel line in that area with a length of DEI Heat Shield Sleeve and wrapped the exhaust pipe there with some DEI Heat Shield Wrap. See the photo for details.
I drove the car, stopping a few times to check the sediment bowl for bubbles. None. Fingers crossed, problem solved.
Old 04-26-2021, 07:49 PM   #14
dmsfrr
dmsfrr's Avatar
The work looks very nice but how close they are to each other makes me nervous.
If there's a way to relocate that fuel line farther away it could be an excellent idea.
Don't want to hear about you on the news for a bad reason.
Old 04-27-2021, 06:05 PM   #15
JMFL36
JMFL36's Avatar
Yeah, I'm going to see if I can bend the fuel line to get a few inches clearance between it and the exhaust. The line is a new pre-bent stainless line from Classic Tube, but I'm guessing the factory must have rerouted the line in that area for optional dual exhaust cars.
Old 04-27-2021, 07:21 PM   #16
KULTULZ
KULTULZ's Avatar
Thumbs up Re: Fuel line check valve?
Regardless, good diagnostic skill ...
- WHY IS IT ... -
Old 05-04-2021, 07:31 AM   #17
JMFL36
JMFL36's Avatar
Yeah, I probably could have added this to that other thread but it turned out there were two separate problems I was fighting - a blocked vent tube (previous thread) and vapor lock (this thread). So hopefully the separate threads will help others find what they're looking for. Thanks again to everyone for all the good advice.
