Old 04-08-2021, 11:00 AM   #1
flathead 39
flathead 39's Avatar
Default hayden automotive 3647 adjustable thermostatic fan control
I have an alum radiator with an electric fan that runs continuously when ignition is on. Looking at the Hayden automotive 3647 adjustable thermostatic fan control. Anyone had any experience with this or similar?
Much improved since Henry sold it.
flathead 39 is offline   Reply With Quote
Old 04-08-2021, 11:30 AM   #2
TJ
TJ's Avatar
Default Re: hayden automotive 3647 adjustable thermostatic fan control
You can fix that fan so you can turn it on manually when you need it. Mount a manual switch and run the hot wire to the switch and one from the switch to the fan.
Old 04-10-2021, 09:29 AM   #3
Shoebox
Shoebox's Avatar
Would really recommend using a relay as well, if you're not already.
I went, I saw, I bought the T shirt
51 Ford Deluxe Tudor
32 Ford roadster
39 Mercury Towncar
Shoebox is offline   Reply With Quote
Old 04-10-2021, 10:14 AM   #4
flathead 39
Hayden has built-in relay.
Old 04-10-2021, 10:58 AM   #5
Jack E/NJ
Jack E/NJ's Avatar
A dash switch that provides a ground path for the fan's ground wire is also useful. Snap-disc thermostats like Hayden's typically have unadjustable open(turn-off) deltas quite a bit below their close(turn-on) set-points. So the fans run & draw 10A or more even when not needed or on trying to re-start a still luke-warm engine. Jack E/NJ
Jack E/NJ is offline   Reply With Quote
Old 04-11-2021, 03:05 AM   #6
1oldtimer
1oldtimer's Avatar
I've used these kits before as I don't like the push in probes.
https://hotronicsproducts.com/category/cooling/
1oldtimer is offline   Reply With Quote
Old 04-11-2021, 12:27 PM   #7
expavr
expavr's Avatar
I agree about the use of a push in probe. I had one fail on a road trip and ended up having to do surgery and bypass the sensor to get back home. I subsequently wired an On/Off toggle switch in the fan motor electrical loop. This hotronics sensor looks to be a good solution but I would still put a toggle switch in the loop just in case.
expavr is offline   Reply With Quote
Old 04-11-2021, 04:33 PM   #8
JayChicago
JayChicago's Avatar
No experience with the Hayden unit. Vintage Air no.24675-VUT was on my '37 with aluminum radiator when I got the car. Works well, no problems so far. The on/off delta is about ten to fifteen degrees. No separate relay required. Speedway sells it for $39.
I don't have a switch on the dash. Yes, fan is on upon start-up sometimes, but that never has been a problem for me on this car.
JayChicago is offline   Reply With Quote
Old 04-11-2021, 10:31 PM   #9
1oldtimer
1oldtimer's Avatar
Super easy to do, last one I did I put in a toggle just in case.
Old 04-12-2021, 06:43 AM   #10
flathead 39
Where did you install the switch? I'm wondering if a switch can be installed from the a/c override wire (green) to a 12v source.?
Old 04-12-2021, 08:26 AM   #11
TJ
TJ's Avatar
O.K. are we dealing with a flathead motor or a late model motor?
Old 04-12-2021, 10:13 AM   #12
flathead 39
8ba
Old 04-12-2021, 10:18 AM   #13
tubman
tubman's Avatar
Ah! a "late model flathead"!
Old 04-12-2021, 10:38 AM   #14
Jack E/NJ
Jack E/NJ's Avatar
If the green wire controls the clutch, should also be able to use it to control the fan relay. Jack E/NJ
Old 04-16-2021, 08:24 AM   #15
flathead 39
Finally 'got 'r done', well almost. Have to run the green (a/c override) wire through a switch to 12v, and finish adjusting the set point down to 180/160. First test, fan came on at 220 off at 200 and I have it down to 200/180 now. Then clean up the mess I made of the wiring & call it a day. Really like not hearing that fan running all the, Thanks for the help and advice.
