Old 04-07-2021, 01:12 PM   #1
Dutchiescoupe
Default 1935 Ford Coupe meassurements , dimentions
Hello,
I could not find the information i need on internet.
I got my 1935 Ford 5 window coupe in bits and pieces.
A lot was cut and lost and i bought some aftermarket stuff but i realy need some information from a stock car.
If someone would meassure fixed points on there ford it would be much appriciated.
On the outside of the chassis between the door and rear fender there is the first bodymount, on that point it looks level, bottom chassis to ground.
front tip and rear tip of chassis to ground.
Front axle to chassis near the bumpstops and rear axle to chassis near bump stops.
Any usefull meassurements are welcome, pictures, drawings, anything.
Dutchiescoupe is offline   Reply With Quote
Old 04-07-2021, 01:31 PM   #2
deuce lover
deuce lover's Avatar
Default Re: 1935 Ford Coupe meassurements , dimentions
Here,from Wescott
http://www.wescottsauto.com/WebCatal...ram1935-40.pdf
deuce lover is offline   Reply With Quote
Old 04-08-2021, 02:06 PM   #3
Dutchiescoupe
thanks a lot
Old 04-08-2021, 02:14 PM   #4
Dutchiescoupe
Originally Posted by Dutchiescoupe View Post
thanks a lot
this does not mention the distance between chassis and ground
Old 04-08-2021, 02:49 PM   #5
deuce lover
That is something you have to determine.
Old 04-08-2021, 07:30 PM   #6
JSeery
JSeery's Avatar
It is going to depend of the springs, spring mounts, tire size, etc.
Old 04-09-2021, 12:26 PM   #7
Dutchiescoupe
nope i'm asking from a stock 35 ford 5w coupe. not dropped not with billet wheel. STOCK HEIGHT
Old 04-10-2021, 01:29 AM   #8
Jembow
Jembow's Avatar
My avatar 3 window is unmolested 23,000 miles. What dimns do you still need?
Jembow is offline   Reply With Quote
Old 04-10-2021, 03:32 PM   #9
Dutchiescoupe
underside chassis to ground near first bodymount . distance between axles and chassis near bumpstops.
Old 05-03-2021, 11:32 AM   #10
Dutchiescoupe
no additional info guys?
Old 05-03-2021, 03:39 PM   #11
JSeery
JSeery's Avatar
Axle distances and bump stops was provided. The rear bump stop in centerline of the axle. Not sure on the front for that year. I guess I'm confused here. The distance between the frame and the axles, is that what your looking for?
Old 05-04-2021, 01:30 AM   #12
Jembow
Jembow's Avatar
Did you pick up my PM?
Old 05-04-2021, 11:26 PM   #13
JM 35 Sedan
JM 35 Sedan's Avatar
Hello,
Maybe you could find someone local to you who owns a stock '35 5w coupe, and get the measurements and pictures you need.
John
Old 05-04-2021, 11:35 PM   #14
petehoovie
petehoovie's Avatar
Hello,
The only thing nice about being imperfect is the joy it brings to others....
"Silver rings, your butt! Them's washers!"
"We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969
https://www.youtube.com/watch?v=7NReUd2_0u0
