04-01-2021, 08:14 PM | #1 |
Who can 6v to 12v shop SoCal
Looking for a shop that can do this for me. Also set the timing and other small things. I’m not in a rush but want a good job. I’m located in Orange County, Ca.
04-01-2021, 08:34 PM | #2 |
Re: Who can 6v to 12v shop SoCal
04-01-2021, 09:32 PM | #3 |
Not a difficult job at all, so should be a lot of candidates. I would check with any local V8 club members or other locals that work with older cars.
04-02-2021, 04:02 PM | #4 |
It’s a 36’ Ford Phaeton v8. I wanted to do the conversion myself but just looking to have it done right and she won’t start. So other issues need to be fix. Hot rod shop?
04-02-2021, 04:59 PM | #5 |
Welcome to the Forums mlhayes5.
So it's 6V now, and it doesn't start?
04-02-2021, 05:02 PM | #6 |
04-02-2021, 05:58 PM | #7 |
Leve it at 6 volts unless you are attempting to have updated electronics in the car. A good 6 volt battery a good ground to the block and a 6 volt system is rarely the root cause of an issue.
Just my thoughts |
04-02-2021, 06:08 PM | #8 |
Hayes - I sent you a PM, I am in Orange County.
Henry Ford designed the flathead without the aid of a computer. |
