02-08-2021, 12:24 PM | #1 |
1954 ford car coil wire
i would like to find out if a 1954 ford sunliner v8 originally had a brown color coil spark plug ignition wire like 1955-1957 ford's have?
03-07-2021, 10:15 AM | #2 |
Re: 1954 ford car coil wire
Could have been made when the change over came ,but if it’s hot when the ign is on use it !
03-07-2021, 11:35 PM | #3 |
All '54 Fords, regardless of engine option or body style, used the same ignition switch and same coil. Follow the wire to see if it goes to the IGN terminal on your switch. If it does, use it.
03-08-2021, 01:48 AM | #4 |
54sunliner may be asking about the hi voltage wire from the center terminal of the ignition coil to the center of the distributor cap.
03-08-2021, 11:39 AM | #5 |
03-08-2021, 11:41 AM | #6 |
Sal |
03-08-2021, 07:58 PM | #7 |
the 54 fords had a black wire
04-08-2021, 08:05 AM | #8 | |
See Attachments Below -
***** - DISCLAIMER -
The above posted information is in my opinion only (IMO) and may contain copy and paste material(s). In addition, any above tech information is supplied in good faith. No responsibility implied or otherwise can be accepted for the way others use or interpret provided data. Your experience(s), opinion(s) and mileage may vary. DIAGNOSED CDO - (OCD In Correct Alphabetical Order) Last edited by KULTULZ; 04-08-2021 at 08:10 AM. |
04-08-2021, 08:09 PM | #9 |
But some wires were brown, especially the 55-57. They also had a loose knot in them
Thread Tools | |
Display Modes | |
