Old 09-22-2019, 08:17 AM   #1
1930deluxe
Default 1930 Generator
My voltage gauge is not working. Is my wires hooked up right on my generator?
1930deluxe is offline   Reply With Quote
Old 09-22-2019, 08:20 AM   #2
midgetracer
midgetracer's Avatar
Default Re: 1930 Generator
It appears to be hooked up right.
midgetracer is offline   Reply With Quote
Old 09-22-2019, 10:42 AM   #3
jrelliott
jrelliott's Avatar
The meter in Model A is an amp meter which shows the direction of current flow from the generator to the battery when a positive reading is seen, or a negative reading when the battery is supplying more current than the generator is putting out. Your connections look correct.
jrelliott is offline   Reply With Quote
Old 09-22-2019, 10:58 AM   #4
sethkestenbaum
sethkestenbaum's Avatar
Do you show charge if you bypass the cutout?
Seth Kestenbaum
www.oldcarroadtrip.com
sethkestenbaum is offline   Reply With Quote
Old 09-22-2019, 11:22 AM   #5
Badpuppy
Check starter-mounted fuse, if there is one.
Badpuppy is offline   Reply With Quote
Old 09-22-2019, 11:23 AM   #6
rotorwrench
rotorwrench's Avatar
Turn on the lights and see if it goes toward discharge. The reproduction amp meters are not too well made. The originals work very well but they can wear out. Generators can wear out too. Batteries will go bad if they set too long.
Old 09-22-2019, 11:41 AM   #7
30 Closed Cab PU
You did mean ammeter, yes?
30 Closed Cab PU is offline   Reply With Quote
Old 09-22-2019, 12:04 PM   #8
Purdy Swoft
Purdy Swoft's Avatar
I would first check the adjustment of the adjustable third brush in the generator . Push down on the aDJUSTABLE brush to increase charge rate . raise the adjustable brush to decrease charge rate .. If the adjustable brush is raised all the way up , it could be the problem . Charge rate is adjustable on the model A generators .
Old 09-22-2019, 12:30 PM   #9
Patrick L.
Patrick L.'s Avatar
What is meant by the ammeter not working ?
Turn on the lights, does it show a discharge ? If it does its working.
If you loosen the fam belt and feed power to the generator it should run like a motor very slowly. Thats a fairly good indicator that the generator is good. If your cut-out is an original type the generator output is constant if the engine is running fast enough.
So with the engine running the ammeter should show a charge if the engine is running at a fast idle speed. As Purdy mentioned the third brush is adjustable and accessed by removing the rear band. If the generator does motor when powered but not show a charge on the ammeter then either the cut-out is bad or maybe the system just needs to be polarized. To do that just touch a jumper wire across the 2 cut-out terminals for a nano-second and let us know what happens.
Old 09-22-2019, 05:25 PM   #10
Purdy Swoft
Right on !!!
Old 09-22-2019, 08:16 PM   #11
1930deluxe
Yes, amp meter
Old 09-22-2019, 08:19 PM   #12
1930deluxe
What does the starter fuse do?
Old 09-22-2019, 08:21 PM   #13
1930deluxe
I took the generator Van's Electric and it tested good it is charging.
Old 09-23-2019, 05:55 AM   #14
Patrick L.
Patrick L.'s Avatar
Then it may now be OK, it was probably polarized during the testing. It could have been checked as stated.
