Old 09-12-2019, 08:12 AM   #1
1930deluxe
Default Speedometer
The speedometer on my 1931 tudor sedan is not working. I took the cable lose from the drive shaft. I can not turn the inner drive cable. It moves in and out but won't turn. Do I need to replace the speedometer?
1930deluxe is offline   Reply With Quote
Old 09-14-2019, 06:43 AM   #2
chap52
chap52's Avatar
Default Re: Speedometer
You can remove your speedometer and bench check it with an electric drill. Guess you could remove the cable from the transmission and attach a drill to the inner cable under the car and see if the speedo responds. If not put on some gloves and pull out that inner drive cable, may find that it is broken.
If you determine that the speedo spins OK then it is in the lower drive unit and the gear may be shot. If that is the case be sure that you order the correct one, there are a few different gear choices. Chap
chap52 is offline   Reply With Quote
Old 09-14-2019, 06:36 PM   #3
DannL
DannL's Avatar
I too have a bad speedometer. At some point in this life it bound up so hard that it broke the speedometer cable about 4 in from the speedometer itself. Ordered one and expect it should be in here shortly. Had to replace the cable also.
DannL is offline   Reply With Quote
Old 09-14-2019, 09:42 PM   #4
Mark in MT
Check the speedometer head itself, the input should turn easily with the tips of your fingers. Any tighter and you will have cable problems. The grease in the speedometer is 90 years old and hard as a rock if it has not been serviced.
Mark
Mark in MT
Always looking for another opportunity to be wrong.
Mark in MT is offline   Reply With Quote
Old 09-15-2019, 07:38 AM   #5
1930deluxe
Thanks to all of you for you advise. This is very helpful.
Old 09-16-2019, 12:12 AM   #6
Mike V. Florida
Mike V. Florida's Avatar
If you feel like attacking it yourself,
http://www.modelahouse.com/tech/speedometer/index.html
Old 09-20-2019, 07:02 PM   #7
papanick
Hay things are slow so you can always send it my way for a rebuild.
papanick is offline   Reply With Quote
