01-12-2019, 12:56 PM | #21 |
Re: Modern post manufacture shock absorbers
About VW type III shocks ... sorry maybe not everyone knows this:
The VW Type III is also known as Fastback or Squareback and these are the shocks mentioned in post #3. Also made 1962 to 1968 in single and dual carburetored versions and called Variant or "VW 1500" outside USA. It's the Electronic Fuel injected VW 1600 that debuted in 1969 and was made until 1973. As I remember they have an eye on both ends like the third picture of post # 20 above. I could check the set of Koni adjustables for the Type III that i have but at present I have not been able to remember where they are. Last edited by Benson; 01-12-2019 at 01:22 PM. |
01-12-2019, 04:31 PM | #22 |
See Empi 9600 series; pure oil filled, no gas charged.
Eyes both ends, metric holes. |
01-12-2019, 05:54 PM | #23 |
Hi Woofa,
I had a comparible problem. The rear spring of my roadster was left very hard, right very very soft. The blades of the spring was on the ends abrassed(?)/scratechd(?) at 0,5 mm deep. I used https://www.oks-germany.com/de/produ...aertend-spray/ Now the spring glides softley on both sides.
Beste Gruesse aus Deutschland, Werner Ford Model A, Roadster, 1928 Citroen 11 CV, 1947 Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version |
01-12-2019, 08:22 PM | #24 |
Do what Lawrie suggests, OR after cleaning, grinding the burrs, etc, buy & apply Graphite paint available at Tractor supply stores, then reassemble. This works well and doesn't require wrapping the springs, as the paint won't attract dist, etc., as the grease will.
01-12-2019, 08:59 PM | #25 | |
This seems to be an air hardening molly spray. Anything the dust doesn't stick to would be good here, as some of it is very fine and in bulk quantity. However, I can't seem to find a dealer for OKS here unfortunately. I would be happy to add it to my collection of spray cans of stuff dust doesn't stick to. |
01-12-2019, 10:56 PM | #26 |
I had my spring off so there was not a problem with lubricating it. I merely loosened the center bolt somewhat( Be very careful not to loosen it too much,Springs are very dangerous!) Besides, you're only creating a small where oil can pass through (It gets trough the .001 gap between the crank and the bearings, doesn't it?). Saturate it with oil for a day or two while the spring is on it's side. Then blow it out with compressed air and saturate it again and stand it up for a day or two so the oil penetrates down between the leaves then turn it over so the oil (STP, 600w, corn head grease, old drain oil, graphite, what have you!) seeps into the other side. When all done, tighten the center bolt to tighten the spring pack and reinstall. Terry |
01-13-2019, 11:16 AM | #27 |
Hello Updraught,
yes it's like MoS2 "paint". In USA it is manufactored by Dow Corning. The general meaning is "Anti-Friction-Coatings". The picture showes my declamped spring. Several times before I tried to get a smoother function with very thin penetrating oil (WD 40 is known in USA?). Thats no really help! You see, that the leaves are dry.
01-13-2019, 01:00 PM | #28 | |
01-13-2019, 03:22 PM | #29 |
thankyou to those who gave some excellent advise. AL in NY tells me the pickup spring is more ridged than the cars so I think I'll either talk to a spring setting business or replace at least the top ridged spring. With that I will replace the shackles as well. thanks again fellas. gary
I know many things, But I don't know everything, Sometimes I forget things. And there are times when I have a long memory. |
01-13-2019, 03:48 PM | #30 |
Like I said ,my 28 ccpu rides as good as my modern cars,drove it all the way to Murray Bridge on all the back roads from central Queensland as smooth as.you dont have to change the spring,
also takes loads of stuff to the tip without a drama.so it can handle a load Lawrie |
01-13-2019, 04:40 PM | #31 |
I got a kit from the late Rainmaker Ron. Oil filled, and they are great. Been on for about 10 years, and I love em'.
