Old 04-02-2018, 08:58 AM   #1
woofa.express
woofa.express's Avatar
Default odd type of radiator
I purchased my pickup with the running gear mostly rebuilt. because I have had cooling difficulty I have looked at many aspects of the system. the radiator doesn't have cooling tubes but one channel running from front of radiator to rear. it has 6 horizontal fins per one inch vertical.
what is odd is the air enters the front then turns 30 degrees to the left as viewed from the drivers seat.
I would welcome comments from those who may be familiar with this type.
thankyou, gary
woofa.express is offline   Reply With Quote
Old 04-02-2018, 09:30 AM   #2
katy
katy's Avatar
Default Re: odd type of radiator
Got any pictures?
Old 04-02-2018, 11:07 AM   #3
Bob C
Is it a honeycomb radiator? See link https://www.thebrassworks.net/restor...radiators.html
Bob
Old 04-02-2018, 04:24 PM   #4
d.
sounds like a honeycomb replacement core...not factory supplied.
d. is offline   Reply With Quote
Old 04-02-2018, 05:28 PM   #5
Jacksonlll
Jacksonlll's Avatar
Send a message via ICQ to Jacksonlll
I think Chevy used this design.
Jacksonlll is offline   Reply With Quote
Old 04-02-2018, 07:10 PM   #6
woofa.express
Originally Posted by katy View Post
Got any pictures?
hi Katy. thanks for your reply. a picture could not show these internal tube substitute. I hadn't noticed it until I took a look to count the tubes. it's outer appearance looks like a normal radiator. cheers, gary
Old 04-02-2018, 07:11 PM   #7
woofa.express
Bob
no, it's not honeycomb. both front and rear look like any modern radiator.
thanks for your comments. cheers, gary
Old 04-02-2018, 08:13 PM   #8
fastroadster
This was a replacement core. Some small radiator mfg probably designed his own fin type. I have worked on and repaired many of variations of this fin type. If you look around top tank, a lot of mfg. would put their name or brand on it.
fastroadster is offline   Reply With Quote
Old 04-04-2018, 02:14 PM   #9
woofa.express
thankyou all for your comments.
a photo shows it to be just like any normal modern radiator.
the comment on Chevy may be quite pertinent and so too the comments on a small manufacturer having made this. think I will buy new 3 core pressurized unit.
thankyou again, gary
Old 04-05-2018, 04:20 PM   #10
d.
Gary,
why are you considering a pressurized radiator? If you are running an original 4 cyl. Model A engine, there is no need to pressurize.
A Chev. 350 might warrant what you are proposing, otherwise, no need.
Old 04-05-2018, 05:02 PM   #11
Synchro909
Synchro909's Avatar
Originally Posted by d. View Post
Gary,
I don't understand how you can say that without knowing the driving conditions, terrain, speed etc etc. I have what is supposed to be the best radiator in my car and it sometimes over heats. It is a pressurised Brassworks radiator. I'm disappointed with it and that is why. I need more cooling and before some armchair expert decides it is blocked or that there is rust in the block or some other thing, all of those things have been taken care of.
Henry was a tight ass. He didn't spend any more on a car than he had to, including the radiator. Cooling on a Model A is marginal. Any extra that can be gained is a bonus and very much needed in the right circumstances.
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 04-09-2018, 03:58 PM   #12
woofa.express
Gary,
why? This overheating has gone on for too long. I have installed a radiator shroud and 5 blade plastic fan. Had radiator cleaned and rodded. I've had enough of it. I can't maintain 40mph on a moderate temp day. I'm open to suggestions thus this thread in this forum. Help will be received with gratitude.
Old 04-10-2018, 11:09 AM   #13
1931 flamingo
1931 flamingo's Avatar
Timing, timing, timing. Initial and how you use the spark lever when driving. JMO
Paul in CT
Old 04-10-2018, 11:28 AM   #14
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
[QUOTE=Synchro909
Henry was a tight ass. He didn't spend any more on a car than he had to, including the radiator. Cooling on a Model A is marginal. Any extra that can be gained is a bonus and very much needed in the right circumstances.[/QUOTE]
So you’re saying ford made a car and sold 5,000,000 configurations all over the world, with an under designed cooling system? Seems like a bad Business plan.
Aren’t you the one who tows a trailer on your trips? That would certainly add heat and possibly overheat a stock system. Do you have engineering data to support your underdesigned theory? I’m seriously curious.
Old 04-10-2018, 11:59 AM   #15
jhowes
If you read the tests that have been done on the 6 blade fan, it buys you nothing. The two blade as supplied by the factory gives the best performance. Jack
jhowes is offline   Reply With Quote
Old 04-10-2018, 02:27 PM   #16
woofa.express
thanks Ben
Old 04-10-2018, 03:06 PM   #17
40 Deluxe
Paul in CT
I second the notion!
Old 04-11-2018, 02:26 AM   #18
woofa.express
hello Paul. even with spark retarded in pings or knocks . I reckon I got the timing correct although I haven't checked the dimple against the physical position of number one. consensus says I have a failed head gasket. will replace that soon. thanks, gary
Old 04-11-2018, 08:24 AM   #19
katy
katy's Avatar
Gary, have you tried replacing the radiator w/one from one of your other cars, to see if it makes a difference?
Possible rust/scale build-up in the engine block?
Old 04-13-2018, 06:26 AM   #20
woofa.express
hi Katy. no I never gave that a thought. just think I might get a new one even a pressurised one. I've sorta grown tired of the whole thing. cheers, gary
