06-24-2017, 09:20 AM | #1 |
Oil for diesel engines
Walmart had Castrol 15/40 Diesel at $10 for 4 quarts,just wondering if there is any reason this would not work in the flathead ,is there that much difference than regular gas engine oil?
DON P |
06-24-2017, 09:25 AM | #2 |
Re: Oil for diesel engines
I have used Castrol 20/50 in my old Fords for over 30 years. G.M.
www.fordcollector.com |
06-24-2017, 09:34 AM | #3 |
the additives in diesel oil are suitable for older engines that run 'dirty'---more additives to control acid, and carbon from blowby-----ideal for old gas engines that don't get run a lot and have less than perfect mixture control
06-24-2017, 10:28 AM | #4 |
And they have extra zinc additive. I have always run either shell rotella or chevron delo 15-40 in my flatheads. My other rigs are mostly diesels so one oil keep on the shelf.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
06-24-2017, 11:29 AM | #5 |
after I installed my fresh flatty I talked to the "oil guy" he is always quick with the answer and fast to show you in his thick spec book, he said the additive pack in diesel oils is among the best shell rotella T1 strait 30 is what he would recommend and added any diesel grade oil would be good.
06-24-2017, 04:39 PM | #6 |
06-24-2017, 07:22 PM | #7 |
Been using Rotella for 15 years
06-24-2017, 07:46 PM | #8 |
Me 2 (not for 15yrs) but Rotella 15/40
Thanks Andy 1952 F1 |
06-25-2017, 05:04 AM | #9 |
15-40 here! As instructed by THE Flathead King {Walt Dupont]
06-25-2017, 06:18 AM | #10 |
06-25-2017, 04:10 PM | #11 |
Diesel oil has recently undergone a formulation change required by the manufacturers. It has reduced the amount of heavy pressure additive, and is not recommended for non diesel use. I have used Castrol 25W-40 for many years.
