Old 06-02-2016, 07:58 PM   #1
1932 V8
1932 V8's Avatar
Default 37 Flathead Raised deck ??
Like the title says, how about a 37 block with a raised deck ( or more accurately a lowered block) I was going to post this in the Flathead identification thread but if there is a simple answer or I missed it in the thread then I don't want to ad this and clog up the thread. This is all assumptions on my parts but I see w/p's in the block, 21 studs and a 78 on the bell housing. 78 should be 1937 but maybe not ? The raised deck is the only thing that doesn't fit . Anyone have more info ??
1932 V8 is offline   Reply With Quote
Old 06-02-2016, 08:50 PM   #2
petehoovie
petehoovie's Avatar
Default Re: 37 Flathead Raised deck ??
That's a nice and clean looking block....Is it NOS?....I just now checked the block in my original '37 and its deck is not raised....
The only thing nice about being imperfect is the joy it brings to others....
"Silver rings, your butt! Them's washers!"
"We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969
https://www.youtube.com/watch?v=7NReUd2_0u0
Old 06-02-2016, 09:00 PM   #3
ford38v8
ford38v8's Avatar
I have no documentation, but I believe your block to be a service replacement. 78's were built for '37s, '38's, industrial engines, and service replacements for those years as well as for earlier cars having pump-in-head (this version would also have the block-off plate installed). Improvements made in engine design were not limited to production engines, but were applied to all engines where possible, which would explain your raised deck.
Alan
Old 06-02-2016, 10:38 PM   #4
38 coupe
38 coupe's Avatar
I think you have a later service motor. Your engine would not have been installed by Ford into a vehicle on the production line. Your motor was probably cast in 41 or early during WW2 as a direct replacement item for 32-38 V8 use.
Old 06-03-2016, 12:53 AM   #5
1932 V8
1932 V8's Avatar
Thanks Ford38V8 and 38 Coupe. That would make perfect sense. I need to see if this is a good block or not. It may be for sale soon .
Thanks , Mike
Thread Tools
Display Modes
