04-10-2021, 03:04 AM | #1 |
1933/34 dual gauge temp sender unit (hose part).
Hi guys,
I am looking for the part on a 1933/34 dual gauge (new or used) that clamps thru the radiator hose that accepts the sender unit. Are these being reproduced at all? Thanks Graham |
04-10-2021, 05:38 AM | #2 |
Re: 1933/34 dual gauge temp sender unit (hose part).
At one time they were,not anymore. No market for them.
04-10-2021, 09:23 AM | #3 |
Not that long ago I got what you are talking about from Randy at a gauge place in Arizona.
The same place that can repair the temp gauge part. |
04-10-2021, 10:15 AM | #4 |
04-10-2021, 10:25 AM | #5 |
Thanks deuce roadster , I totally forgot about Randy at RS Gauges.
04-11-2021, 11:03 PM | #6 |
So, is someone able to post or message me some close up picture and dimensions so I could look at having one made. Thanks in anticipation. Graham Freeman |
04-12-2021, 08:38 AM | #7 |
Don't the 35-36 and aftermarket water pumps have a threaded port in them?
04-12-2021, 08:45 AM | #8 |
Bob Drake’s water pumps
04-12-2021, 08:45 AM | #9 |
04-12-2021, 08:53 AM | #10 |
04-12-2021, 01:24 PM | #11 |
OOps
04-12-2021, 03:23 PM | #12 |
04-12-2021, 03:37 PM | #13 |
Thanks guys but I need details of the piece that takes the bulb that clamps into the hose.
04-12-2021, 04:39 PM | #14 |
Graham,
I believe that this is what you are seeking. Please let know if you want the various dimensions. |
04-12-2021, 05:15 PM | #15 |
Thanks David,
Yes exactly what i am looking for. Some close up pictures and dimensions would be great. Regards Graham Freeman |
04-12-2021, 05:27 PM | #16 |
The common lower hose heater hose fitting looks similar. Maybe one could be modified?
04-13-2021, 08:42 AM | #17 |
04-13-2021, 10:22 AM | #18 |
Graham,
Most of the originals that I have encountered were made entirely of brass with the part that fits inside the radiator hose cast to create a lip surrounding the threaded portion to affect a good leak proof seal. Some have steel hex nuts rather than brass. The dimensions are as follows: -- the base of the threaded portion that fits inside the radiator hose is 1 1/4" x 1 5/16" with the latter running front to back (I've several and all have that minor variation in their overall dimensions). The raised cross section at the top of the curve from the end view is 9/32". The radius is that of the inside of a upper radiator hose although it works equally well in both V8 and larger B outlet hoses. The 11/16-14 threaded portion is 3/4" and the overall height is 1 1/4". The recessed area above the threads is 3/32" and the inside of the opening at the top is slightly countersunk. -- the outer portion measures 1 1/8" x 1 1/8". The hole in the center is 3/4". The thinnest cross section is 1/16" thick and the thickest cross section is 3/16" -- the 11/16-14 hex nut is 1/4" thick and 31/32" across the flats although others have a nut 1 1/8" across the flats. I'll try for better photos later today, but for the best quality it would be best if I sent them via email. For that, please p.m. me your address. Last edited by DavidG; 04-14-2021 at 05:37 PM. |
04-14-2021, 03:59 PM | #19 |
David,
Did my email address get to you yesterday by PM? Graham |
04-14-2021, 04:22 PM | #20 |
1933/34 Dual Gauge Fuel and Temp Sender Unit. |
