Old 09-11-2020, 09:06 AM   #1
Bob Bidonde
Bob Bidonde's Avatar
Default Trying Something Different For Heat
As an experiment for a comfort heat source, I am installing 12V heated seat covers, one in the back seat and one on the front seat. If this works, I will install two more heated seat covers.
The covers are Sojoy Item SJ115R054, and they are equipped with a controller containing ON-OFF, High, Medium & Low heat, power indicator LED, a fuse and a power connector. Current draw is 2.6A and Max Power is 45W. My Model "A" has a 12V 60A Alternator.
Has anyone out there done this? If so, please share your experiences.
Bob Bidonde
Old 09-11-2020, 09:12 AM   #2
jwilliams81
jwilliams81's Avatar
Default Re: Trying Something Different For Heat
Interesting idea. You could also try more of a bench seat pad.
https://www.amazon.com/Zone-Tech-Hea.../dp/B01N946KB1
1931 Murray Town Sedan. Black body with Apple Green pin stripe.
1923 Model T Touring with electric start. Low radiator
Cincinnati, Ohio
jwilliams81 is offline   Reply With Quote
Old 09-11-2020, 09:54 AM   #3
Bob Bidonde
JWilliams, good thinking re the bench pad. If the pads I have work, I will use them on the front seats of my Victoria, and buy a heated bench seat pad for the rear seat.
Bob Bidonde
Old 09-13-2020, 11:42 AM   #4
ronn
I likes the idea.........pls report back with the results.........
Old 09-13-2020, 03:34 PM   #5
Chris in WNC
Chris in WNC's Avatar
depends on the quality of the seat covers, I guess.
we got one for the passenger seat in my 2000 Ranger truck and were not satisfied with the performance.
our next Model A is out there in the unknown......
Chris in WNC is offline   Reply With Quote
Old 09-13-2020, 08:33 PM   #6
McMimmcs
McMimmcs's Avatar
Unfortunately you are only getting your bum warm. Better to put in a hot water heater with a fan and get your whole body warm.
Old 09-13-2020, 10:37 PM   #7
Peyton
Second McMimmics suggestion. An alternative to manifold heaters with increased danger of carbon monoxide entering the car. Has worked well for us.
Peyton is offline   Reply With Quote
Old 09-14-2020, 05:13 AM   #8
shew01
shew01's Avatar
How about something like this?
ANTARCTICA Upgraded USB Electric Heated Lightweight Rechargeable Heating Waistcoat Down Jacket Coat (Power Bank NOT Included) https://smile.amazon.com/dp/B07XM5V3..._Ti0xFbTRW0BQN
Old 09-14-2020, 07:13 AM   #9
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Bob, here is some additional comments on this topic;
https://www.fordbarn.com/forum/showthread.php?t=262147
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 09-14-2020, 08:52 AM   #10
Bob Bidonde
Thanks Brent. The bench seat heating pad arrived yesterday, so now I have enough heating pads for all of the seats in 190A.
Bob Bidonde
Old 09-14-2020, 01:48 PM   #11
McMimmcs
McMimmcs's Avatar
No sense having a warm seat and frosted up windows unless you are just going to sit in the driveway !
Old 09-14-2020, 08:26 PM   #12
Ranchero50
This is an option I was thinking about on the speedster before building the seats. At my completion rate it'll be next winter before it becomes an issue.
Building a '29 Speedster, the hard way...
Ranchero50 is offline   Reply With Quote
Old 09-15-2020, 01:56 PM   #13
Jungle Jim
Guys,
I had an Engineering professor that had a great idea to heat homes in the arctic that in a manner that would not affect the permafrost. They installed microwave generators in each room to just heat the people and not the building. It was quite "comfortable", until they learned of the radiation effects. The other side effect was that cutlery was at -50 F as spoon would stick to the inside of your mouth before it warmed up.
Regards,
Jim :-)
Jungle Jim is offline   Reply With Quote
Old 09-16-2020, 10:18 PM   #14
DannL
DannL's Avatar
Here's another option . . .
Not a Purist.
DannL is offline   Reply With Quote
Old 09-17-2020, 10:52 AM   #15
Bob Bidonde
There is no way I am poking a hole through the firewalls of my Model A's for a manifold heater. I have the ram air heater through the floor boards in my Coupe, and it is inadequate but better than nothing. So I am going to have electric heated seat pads in my 190A that I can easily remove in warm weather. I will keep you all posted as I go.
Bob Bidonde
Old 09-17-2020, 11:06 AM   #16
Harpkatt
Harpkatt's Avatar
Sounds like a plan, hope it works out.
Harpkatt is offline   Reply With Quote
Old 09-17-2020, 12:37 PM   #17
McMimmcs
McMimmcs's Avatar
Have fun in the driveway with the frosted windows!
