02-11-2020, 05:59 AM | #21 | |
Re: Coil Tester needed
Hello KR500, I would be thrilled to get an instruction sheet and schematic for my vintage Snap-On MT-640 coil & condenser tester. When were these built? Thank you, Kyle |
02-11-2020, 11:39 AM | #22 | |
The bulb in mine broke in shipping and I haven't been able to find another, there was no number on it. Bob |
02-11-2020, 12:39 PM | #23 | |
Maybe an NE-51? https://www.bulbtown.com/B1A_NE_51_N...Base_p/b1a.htm
If you don't hear a rumor by 10 AM, start one!. Got my education out behind the barn! Last edited by katy; 02-11-2020 at 12:42 PM. Reason: Addition |
02-11-2020, 12:54 PM | #24 | |
You can see the bulb in post #5 between the springs. Bob |
02-11-2020, 01:40 PM | #25 |
02-11-2020, 02:52 PM | #26 |
I'll start the hunt. When I bought it, without the bulb, I did use it too check my Model A coils and it did work. I think it's kind of a "buffer" for lack of a better word..for the bulb. djm |
02-11-2020, 03:06 PM | #27 |
I was thinking maybe it would glow when there was power at the terminals
from the coil being tested so you don't touch them. Bob |
02-11-2020, 05:48 PM | #28 |
02-11-2020, 09:01 PM | #29 | |
12volts, I wonder how well it will work on 20,000 volts |
02-14-2020, 04:06 PM | #30 |
Bob...!
On the panel, it sez,..." use a 6 amp fuse ",...now I'm not sure.. |
02-15-2020, 12:31 PM | #31 |
My Dad from about 1925 on to 1965 made a living as a mechanic. He built a test set of the day, to check current, and leakage current (with a milliamp meter, along with lights for just plain continuity testing and as you can see from the pic's also distributor points with a heater motor with a single lobe cam on the shaft, that speed could be adjusted with a rheostat as well as spark gap of the coil. The unit also worked to test condensers. Clever! Today ya just go buy one or more to do these chores.
