Old 12-08-2019, 05:18 PM   #1
bo8109b
bo8109b's Avatar
Default Radio Static
Can somebody tell me how to get the ignition static out of my '40 sedan Philco radio? I've installed .5mfd suppressors on the distributor, regulator, oil sender, under dash power terminal block and fuel sender in trunk all to no avail. Original 6v system. Carl
bo8109b is offline   Reply With Quote
Old 12-08-2019, 05:21 PM   #2
FrankWest
FrankWest's Avatar
Default Re: Radio Static
you will have to shield the antenna wire with braided mesh that is grounded
FrankWest is offline   Reply With Quote
Old 12-08-2019, 06:30 PM   #3
aussie merc
aussie merc's Avatar
sounds like youve covered everthing but the generator out put terminal try that
aussie merc is offline   Reply With Quote
Old 12-08-2019, 06:38 PM   #4
Black Fifty
Black Fifty's Avatar
Are the spark plug wires solid core?
Black Fifty is offline   Reply With Quote
Old 12-08-2019, 06:52 PM   #5
koates
The noise you are hearing in your radio is caused from the transmission of RF (radio frequency) transmissions from your spark plug wires. You will need a resistor type suppressor on the end of each spark plug wire at the plug or a set of resistor type plug wires. All the other types of condensers which you have fitted are not designed to eliminate that RF type noise. Regards, Kevin.
koates is offline   Reply With Quote
