08-25-2019, 01:53 PM | #1 |
1930 Tudor Sedan
I have tightened the adjustment on the steering box. The car shimmies terrible at 20 mph. Very little shimmy at highway speed. Do I need to have the steering box rebuilt?
08-25-2019, 02:52 PM | #2 |
Re: 1930 Tudor Sedan
Check all the ball joints [ drag link ; tie rod etc] & make sure they are firm but not tight. Next drop radius rod under bell housing & check it has all the original springs & collars ; it must be able to flex, not be rigid. Check steering box is tight at chassis & pitman arm is tight at 'box.
I would read over one of the Model A maintenance books first unless you can do this all in your sleep. I used to have this problem years ago, but correcting the above items cured it. Basically, adjusting the steering box reduces play & improves steering & driveability, but will not always help to eliminate shimmy. Cheers. |
08-25-2019, 04:39 PM | #3 |
It's probably not the steering box. Mine did not go away until I addressed the slop in the way the ball at the end of the wishbone fits into the bottom of the flywheel housing. You should also check the Pitman arm where it connects to the steering gear output shaft. You should have zero play and tighten that bolt as tight as you can. Also check the drag link and tie rod ends.
08-25-2019, 04:45 PM | #4 |
Check wheel bearings first.
Bill Worden 1929 Roadster 1929 Briggs Town Sedan 1930 Closed Cab pickup Smith Motor Compressor 1951 Ford F1 High Desert Model A's |
08-25-2019, 06:43 PM | #5 |
Might start by jacking up the front axle and shaking each wheel horizontally and vertically. Also try to lift each wheel while jacked to see if there is any vertical displacement. Any play in the front end should be obvious. Adjusting the steering box should also be ccomplished with the front wheels off the ground. Good Luck.
08-25-2019, 07:29 PM | #6 |
08-26-2019, 06:17 AM | #7 |
As above, ck for any looseness starting at the pitman arm. Also ck the ball on the end of the wishbone for wear and/or if there's a rubber ball over it. Also ck toe-in. FWIW
Paul in CT |
