Old 03-05-2022, 08:36 PM   #1
quickchange
quickchange's Avatar
Default Coupe parcel tray
I have two 30-31 coupe parcel trays , One is 6" tall the other 5" tall,also the two end mounting brackets are different, one being taller than the other, This would make the tray hang lower , WHY , What is the difference between a standard one & one for a wind down rear window , These are both the same width, Would a wind down rear parcel tray be narrower ,?? Too accommodate the wind down tray & glass, Can,t work out how to put picture on , Thanks Derek in a nice autumn NZ
quickchange is offline   Reply With Quote
Old 03-05-2022, 10:11 PM   #2
Bick in New Zealand
Bick in New Zealand's Avatar
Default Re: Coupe parcel tray
The '31 wind down window parcel shelf is narrower and has holes etc for mechanism
File Type: jpg 67562706_10216989250098041_4675349111770185728_o (1).jpg (56.5 KB, 83 views)
1928 Roadster (CA67)
1931 Deluxe Coupe RHD
1931 Victoria RHD
Model A's don't leak oil they just mark their territory.
Bick in New Zealand is offline   Reply With Quote
Old 03-05-2022, 10:16 PM   #3
quickchange
Justin how much narrower ""like front to back measurement , also how tall is the upstand at the back ? got 3 here , two at %' & one at 6" neither has provision for winder mechanism , also 3rd one has outside mounting tags bent at right angles not vertical ,
Old 03-07-2022, 06:14 PM   #4
quickchange
So can no one tell me if the deluxe wind down rear window parcel tray measurements are different from a standard on ? who has one they can just measure the width?? Thanks
Old 03-08-2022, 05:20 AM   #5
jukenut 16
Hi Derek, I didn't have a shelf so made one to convert to wind down window without modifying stock window wood depth, so not factory measurements.
Page 57 of ''How to restore your model A '' volume 4 gives some measurements and different shelfs. Apparently there were 2 heights ,6'' or 7 1/2'' below window, 5'', 5 1/2'' and 6'' width at center.
jukenut 16 is offline   Reply With Quote
Old 03-08-2022, 06:55 PM   #6
quickchange
Jukenut 16 Thanks for the info , So where are you in kiwiland ?
Old 03-09-2022, 03:16 AM   #7
jukenut 16
Derek, I'm one of your customers....Ron from Wainuiomata
Old 03-09-2022, 03:43 PM   #8
quickchange
Ron found the article, Thanks for reference , With out a picture ,or location ,One never knows who they are talking too, Thanks
