Old 11-11-2020, 02:52 PM   #1
J.Ukrop
Default Intro & Adjustable Lifters Question
Hi everyone,
My name is Joey and I purchased my first Model A in the late summer. It's a 1930 roadster that hasn't run in a long time. When I was inspecting the valves prior to the first fireup, I noticed that everything was extremely clean and that it had adjustable lifters installed. Were these ever stock on Model A's or do you think someone had been through the engine before me?
(I'm building the car into an early-style hot rod, hence the FSI and different ignition wires).
Any input would be greatly appreciated. I've been lurking on here for some time, but I thought I'd introduce myself and ask.
Thank you in advance!
J.Ukrop is offline   Reply With Quote
Old 11-11-2020, 02:56 PM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: Intro & Adjustable Lifters Question
All factory original Valve Push Rods (-a/k/a lifters) were non-adjustable. It would appear someone has made some upgrades to your engine.
Welcome to Fordbarn as an official poster!!
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 11-11-2020, 03:02 PM   #3
J.Ukrop
Thank you for the speedy reply, @Brent. The engine fires easily and runs smoothly. I am wondering if the previous owner did any other work to it. I am happy with it for the time being!
Old 11-11-2020, 03:12 PM   #4
alexiskai
alexiskai's Avatar
I was just looking through the documentation for my coupe, and I found the original invoice for its last engine overhaul in 1984. The owner had cracks in the block repaired, cylinders bored out to .100, connecting rod bearings to .040, crankshaft adjusted, babbitt redone, valve seat inserts, new crankshaft gear, and adjustable lifters. None of that except the lifters is apparent when you're just eyeballing it, so it's certainly possible that more work has been done on yours.
Old 11-11-2020, 04:30 PM   #5
BRENT in 10-uh-C
I wonder exactly what he "adjusted" on the crankshaft??
BRENT in 10-uh-C
Old 11-11-2020, 04:35 PM   #6
Chuck Dempsey
Chuck Dempsey's Avatar
Welcome aboard, Joey. Enjoy your 'A'!
Chuck Dempsey is offline   Reply With Quote
Old 11-11-2020, 04:41 PM   #7
alexiskai
alexiskai's Avatar
I knew you'd hit me on that... this is my recollection of the invoice which I do not have in front of me and which used a lot of shorthand. I believe it referred to correcting the journals for the new ID on the connecting rods and perhaps also the babbitt bearings.
Old 11-12-2020, 12:04 PM   #8
1930artdeco
1930artdeco's Avatar
Welcome to the Barn Joey, I have been following you on the HAMB. Keep up the good work.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 11-12-2020, 12:20 PM   #9
Jim Brierley
Joey,
You may be interested in my book 4-bangers and me? It is about modifying the A/B engines for performance and reliability. e-mail me at [email protected] for details.
Jim Brierley is offline   Reply With Quote
Old 01-21-2021, 01:18 AM   #10
J.Ukrop
Thank you everyone for your input. The engine runs smooth and strong. I am looking forward to getting it dialed in for some longer drives.
Old 01-21-2021, 05:17 AM   #11
Synchro909
Synchro909's Avatar
FYI, If your crankshaft journals are 0.040" under size, that is the limit. It you need to rebuild it again, you'll need another less worn or new crankshaft.
Oh, and welcome to the forum.
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
