Go Back   The Ford Barn > To The Editors > Questions & Suggestions
Old 09-03-2020, 03:18 PM   #1
legacy
legacy's Avatar
Default Rattling noise when the clutch pedal is pushed in
I just got a 1928 Model A with a multi disk clutch. I don't have any experience with Model A.
I was driving the car and something started rattling, it got worse if I pushed in the clutch pedal.
I removed the inspection panel on top of the bell housing. There is a disk that is right ahead of the throw out bearing. It's loose and I can spin it on the shaft, that's what's causing the rattling.
What am I looking at here, and do I need a new clutch assembly?
Thank you
legacy is offline   Reply With Quote
Old 09-03-2020, 07:35 PM   #2
Charlie Stephens
Default Re: Rattling noise when the clutch pedal is pushed in
Welcome to fordbarn. You placed your question in an area intended for questions to the editors about the site. This area is seldom read or responded to. Leave your question here (it costs too much to move it) but you need to place your question here: https://www.fordbarn.com/forum/forumdisplay.php?f=3
Charlie Stephens
