Old 01-09-2020, 09:01 PM   #1
Bob Greenhaus
Bob Greenhaus's Avatar
Default Coolant Leak/Drip From Bell Housing
I installed a small catch pan under the bell housing to catch what I thought was an oil leak from the rear main seal. I asked my mechanic to drop and clean the oil pan and take a look at the rear main leak. He told me that he found the small drip pan full of coolant, not oil. No coolant was found in the oil pan - which was cleaner than feared. There is no sign of any head gasket leak or where the coolant is coming from. Any ideas?
Bob
1930 68B
Bob Greenhaus is offline   Reply With Quote
Old 01-09-2020, 09:05 PM   #2
Bob from Northport
Bob from Northport's Avatar
Default Re: Coolant Leak/Drip From Bell Housing
Gotta be leaking from the back of the head where you can not see it
Bob from Northport
Northport, Michigan
Bob from Northport is offline   Reply With Quote
Old 01-09-2020, 09:33 PM   #3
Bob Greenhaus
That was the thought. Can't see any sign of it. I suppose we'll have to pull the head and replace the gasket?
Bob
1930 68B
Old 01-09-2020, 10:14 PM   #4
Truckerjim
Pull floor boards and look from there it might help.
Truckerjim is offline   Reply With Quote
Old 01-10-2020, 01:02 AM   #5
jm29henry
jm29henry's Avatar
I agree with bob probably a weepy head gasket not blown my a does it only in the winter and has been for the last 10 winters so hopefully you won’t have to do anything just check fluids in the spring
jm29henry is offline   Reply With Quote
Old 01-10-2020, 03:56 AM   #6
SAJ
SAJ's Avatar
Hello Bob,
Twice my water pump has leaked and the green liquid drips down onto the front of the block where the front main bolt sits, then down onto the flange that the sump bolts up to. From there it travels along to the rear of the motor and drops to the ground as if from the bell housing. Some is caught in the "rear main janitor" catch pan I have fitted.
For all the world it looks like if comes from the rear, but actually is just the water pump leaking and travelling, fairly invisibly, down the 3-1/2 degree of rearward engine slope to the bell housing.
SAJ in NZ
SAJ is offline   Reply With Quote
Old 01-10-2020, 12:25 PM   #7
Russ/40
Russ/40's Avatar
Originally Posted by SAJ View Post
Hello Bob,
SAJ in NZ
Ditto, exactly what I found before changing to a leakless pump.
Old 01-10-2020, 12:45 PM   #8
The Master Cylinder
The Master Cylinder's Avatar
I had a leak (oil) that was driving me crazy as I could not see where it was coming from. I used some fluorescent dye and and a ultraviolet light and found it right away.
Maybe it will work on your coolant leak. https://www.amazon.com/Interdynamics...%2C197&sr=8-40
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is offline   Reply With Quote
Old 01-10-2020, 03:00 PM   #9
1931 flamingo
1931 flamingo's Avatar
Try re-torquing the head. FWIW
Paul in CT
Old 01-11-2020, 11:30 AM   #10
Bob Greenhaus
Thanks for all the suggestions. I suppose I should be glad it's not actually oil that's leaking!
Bob
1930 68B
Old 01-11-2020, 04:02 PM   #11
t farr
I had the same problem. Went to the starter side with a mirror and looked up to under the head and fount 3" crack in the block.
t farr is offline   Reply With Quote
