02-09-2018, 07:56 PM | #61 |
Re: Block availability
Interesting article. I had a block junked by a builder because he said it was no good. He said it had cracks between the valve seats. Probably should have held onto it anyways.
02-09-2018, 11:28 PM | #62 |
Don't think so. That one sounded like a real loser. Cracks across valve seats and into cylinder walls are a bad deal usually.
02-10-2018, 08:24 AM | #63 | |
I fixed it because he had a bunch of money tied up in the engine and wanted to save it if he could. I fixed the crack and overhauled the engine, did some sensible porting and ran a Max 1 cam. The engine already had Offy heads and intake with dual carbs. It's in a '51 Ford sedan. Yes it was a little scared at first but once I did the repair it looked really good. The Lock & Stitch company walked me through it after I sent them good pictures of the crack. They have quite a few different styles of pins so they hooked me up with those and I carefully followed their instructions to the letter. It was their recommendation NOT to sleeve as that would have a spreading effect on the area. I should say this crack ran from a center exhaust valve pocket, through the seat and down into the cylinder about 1/2". Yes it looked bad but the engine ran. When I was done you could hardly tell where the repair was done. |
