09-09-2011, 02:31 AM | #21 | |
Re: From running to not running, and no crank?
What's right about America is that although we have a mess of problems, we have great capacity - intellect and resources - to do some thing about them. - Henry Ford II Last edited by Mike V. Florida; 09-09-2011 at 02:43 AM. |
09-09-2011, 02:34 AM | #22 |
Yes you are correct, as long as the wiring is stock, the key only operates the ignition. You can see the draw on the ammeter when the points are closed.
This way your brake light, head and parking lights and horn operate without the key in the On position. The starter is connected directly to the battery via the starter switch. I would put original parts back on until everything works as it should, then you can change out parts one at a time if you want to modify things. Otherwise it make it very difficult to diagnose exactly what the problem is. |
