Old 06-20-2021, 03:37 PM   #1
hazelhoff
hazelhoff's Avatar
Default Hood hinges
Just curiosity … what makes the hood hinges scuff the paint from their opposite counterparts ? In other words, why do we see pictures of cars scuffed and others don’t ?
Henk
You don’t own a Model A ... it owns you !
hazelhoff is offline   Reply With Quote
Old 06-20-2021, 05:13 PM   #2
Oldbluoval
Oldbluoval's Avatar
Default Re: Hood hinges
Because the clearances are not correct. This can happen even with an original 4-panel hood.
I’ve seen it more when assembling odd panels together. A file and trial fitting before painting will go a long way in preventing such
Also the eyelets can get enlarged that affects the opposite panel. I have a die on vice grips that I use to reset the eyelets if distorted. Rods should be a reasonably tight fit but not binding
Oldbluoval is offline   Reply With Quote
