08-09-2020, 12:06 PM | #1 |
GAV needle threads... unique to this component?
Just interested ...The thread on the GAv needle and inside the housing seems to be a real odd ball...According to Model-A.org the threads are 1/4-24. This thread is virtually unknown in UK ... is this thread used much in the states?
08-09-2020, 12:31 PM | #2 |
Re: GAV needle threads... unique to this component?
Outside of the Zenith Model A or Model B carb, I have yet to come across any 1/4-24 threads. The matching tap and die sets are available, however.
08-09-2020, 12:31 PM | #3 |
It is not a very common thread pitch in the US.
I just looked online and McMaster-Carr sells a 1/4-24 tap for about 25 USD. So they are out there. You can thank the French at Zenith for this odd thread.
Jim Cannon Former MAFCA Technical Director "Have a Model A day!" |
08-09-2020, 04:50 PM | #4 |
I am just dealing with this now. We are rebuilding some model B carbs. The GAV
Is 1/4-24 and we need a 1/4 24 bolt for a puller to remove the GAV. Model T magnet bolts are 1/4-24 ,but they are brass. I am going to cut the threads on my lathe for a steel puller bolt. We got the plans for the puller from Renners Corner,they are great to deal with for model B carb information and parts. John
Welcome each day |
08-09-2020, 05:03 PM | #5 |
Isn't it odd that they would use both standard and metric threads on a Zenith. I'm sure there is an old dead engineer someplace laughin' his ass off.
Ruth "Sometimes you really DO need to read the whole thread" |
08-09-2020, 05:17 PM | #6 |
08-09-2020, 07:02 PM | #7 |
1/4 X 24 tpi is not even close to a metric thread.
1/4" is 6.035mm so not 6 mm 24 tpi is a pitch of 1.06 mm not a fit there either. 6mm Metric coarse has a pitch of 1.0 mm. 1/4" Brass is 26 tpi 1/4 UNF is 28 tpi. It seems to me that 1/4" X 24 is a real oddball. It's not even BA All that said, I don't understand the American "gauge" threads. I'd never heard of them till I started playing with Model As. Does it fit one of those?
08-10-2020, 12:34 AM | #8 |
Nobody said it was?
08-10-2020, 03:47 AM | #9 |
thanks everyone .. I guess it's part of the fun of old cars
08-10-2020, 03:59 AM | #10 |
POst #5 "Isn't it odd that they would use both standard and metric threads on a Zenith. I'm sure there is an old dead engineer someplace laughin' his ass off."
08-10-2020, 06:16 AM | #11 |
As other threads in the zenith are metric, could it be a 6mm x 1mm pitch thread. That would be very close to a 1/4" x 24 tpi. I would try a metric bolt or tap of that measurement first.
08-10-2020, 07:06 AM | #12 |
M6-1 is close but doesn't fit -I've tried it. close but no cigar . Though of course one could retap and die things to whatever you like if push came to shove
08-10-2020, 07:09 AM | #13 | |
08-10-2020, 08:52 AM | #14 |
deleted
08-10-2020, 09:31 AM | #15 | |
I was pointing out that I thought it was odd that they use "both standard and metric threads on a Zenith".
Ruth "Sometimes you really DO need to read the whole thread" Last edited by Ruth; 08-10-2020 at 09:39 AM. |
08-10-2020, 09:39 AM | #16 |
Jim, would the Zenith drawings be at Benson Ford Archives since the Zenith carb was made by an outside source and not Ford? Something like Houdaille Shock?
08-10-2020, 09:51 AM | #17 |
Are you sure that they're not #14-24?
Sometimes people mistake #14 for 1/4". 14-24 is an old ASME thread. #14 is .242" diameter.
08-10-2020, 10:31 AM | #18 |
Picking up on what Katy said ...the now obsolete ASME thread standards had number size screws from # 2 (.0842) to #30 (.4526) with many optional thread pitches. Unfortunately there were several sizes that are deceivingly close to the common "inch" sizes. Three of the worst that can cause BIG trouble are #12 (.216), #14 (.242), and #16 (.268) , these came in pitches , 16, 18 , 20 , and 24 tpi.
Joe B |
08-10-2020, 11:12 AM | #19 | |
Over time the carbs were manufactured by Zenith, Holly, and Ford. I would expect to find a drawing there somewhere.
08-10-2020, 11:33 AM | #20 |
Thanks Jim, just curious. I have never been to the Archives.
