Old 02-25-2020, 07:14 AM   #21
30-9
Default Re: 39-40 coupe struts
Originally Posted by JSeery View Post
At one time they had what were called helper springs that looked similar to a coil over.
Looks like they call them load levelers or load adjusters.
Maybe strut was wrong terminology. Load leveler sounds more appropriate.
Thanks - 30-9
1939, 1940
30-9 is offline   Reply With Quote
Old 02-25-2020, 07:28 AM   #22
19Fordy
19Fordy's Avatar
Bite the bullet and install a new rear spring.
Band aid solution isn't a good solution.
Old 02-25-2020, 09:53 AM   #23
rotorwrench
rotorwrench's Avatar
I agree with others that the stance is really not to bad from the photos provided. A lot of times the old springs get crusty and don't move well for compression or rebound. A new spring or a carefully rebuilt spring would help get it up to snuff. Air shocks have a tendency to put a lot of the load on mountings that really weren't designed to carry a lot of load.
Street rods use all the bags & struts but the whole frame is redesiged to get the updated suspension components in there the way that they will best function. I've always felt the the old Fords had really smooth riding suspensions just the way they were designed as long as it is maintained in good condition.
