Old 01-19-2020, 05:12 PM   #1
30-9
Default 40 coupe
Hi Gents
What is the biggest rear tire that will fit in a stock rear?
Thanks - 30-9
1939, 1940
30-9 is offline   Reply With Quote
Old 01-19-2020, 06:18 PM   #2
V8COOPMAN
V8COOPMAN's Avatar
Default Re: 40 coupe
I'm sure you can get a 7.50 X 16" tire in there on a stock Ford 16" X 4-1/2" wide wheel....at the least! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 01-19-2020, 06:22 PM   #3
Krylon32
I'm running 15's. 195/65/15s on the front and 235/75/15s on the rear. They're Diamondback white wall radials. Mines not a restoration more of a road/street car.
Krylon32 is online now   Reply With Quote
Old 01-19-2020, 06:46 PM   #4
19Fordy
19Fordy's Avatar
1st photo is of my 40 in 1971 with stock rear and 15 inch 1950 Lincoln rims
wearing 8:20 x 15's.
5:60x15's were on the stock front end.
2nd photo is same rear wearing 7:60 x 15 tires on 15 in. rims.
If tires are too wide the inner side wall will rub against the rear spring perch.
5:60 x 15's are on the front with 4 in. dropped axle and Posie reversed eye spring.
Don't have any radial tire knowledge or 16 in rim knowledge.
Old 01-19-2020, 09:55 PM   #5
bluardun
bluardun's Avatar
I have a stock '40 rear end and stock 15X5 Ford wheels. I would have liked to use 235X75X15 tires; But found I would have to de-flate them to stuff them under the fender. So, I used 225X75X15 with no issues.
bluardun is offline   Reply With Quote
Old 01-20-2020, 08:31 AM   #6
30-9
Thanks sounds like 235/75/15 is it.
Thanks - 30-9
1939, 1940
Old 01-20-2020, 09:25 AM   #7
TJ
TJ's Avatar
I've been able to use 235X75's under every '40 I have owned.
Old 01-20-2020, 01:18 PM   #8
Ggmac
Make sure you have clearance to change a flat tire if needed.
Ggmac is offline   Reply With Quote
