01-12-2020, 11:11 AM | #1 |
39 rear drain plug
Hi Gents
Trying to drain and replace rear gear oil. The drain plug is square female. What tool do you guys use? I tried my 1/2 it’s too big and 1/4 too small.
Thanks - 30-9 1939, 1940 |
01-12-2020, 11:14 AM | #2 |
Re: 39 rear drain plug
Is it 3/8, like the end of an extension? Can't remember if the 3/8 works directly or if you have to grind them down a bit.
01-12-2020, 11:17 AM | #3 |
I took a 1/2" allen bolt and ground/filed the end square with a slight taper. I haven't used that for ages though, 9 times out of 10 a 3/8 ratchet fits well enough to undo the plugs.
Mart. |
01-12-2020, 11:37 AM | #4 |
3/8" ratchet works fine.
01-12-2020, 12:11 PM | #5 |
The 3/8 ratchet is too small. My old arms/muscles need the 1/2 breaker bar. I also think it’s closer to 7/16 than 3/8. I’ll borrow a 1/2 - 7/16 pipe plug remover socket.
01-12-2020, 12:36 PM | #6 |
"I can explain it for you. However, I can't understand it for you". Last edited by Kube; 01-13-2020 at 08:44 AM. |
01-12-2020, 12:48 PM | #7 |
Kube when your 85 try and let me know how you make out.
01-12-2020, 01:01 PM | #8 |
Hi Everyone, on my '35 and '36 the female square in the rear drain and fill plugs are not an exact fit for a 3/8 extension or ratchet. But that's the tool I use. I just try to be as gentle as possible.
Maybe a long handle 3/8 ratchet or a 1/2 to 3/8 adapter on your 1/2 inch ratchet or breaker bar? I can't believe I'm saying this but maybe a shot of slick-em-up would make it turn easier? I might suggest you make sure the fill plug is free before you try to get the drain plug out.
01-12-2020, 01:08 PM | #9 | |
As we get older, we also tend to misunderstand each other more often, but of course I never had that problem myself.
Alan |
01-12-2020, 01:23 PM | #10 |
Plug may be worn on inside making it look bigger. When you do get it out you could replace it with a male plug which is easier to work with.
01-12-2020, 01:32 PM | #11 |
I use a home made tool for that purpose; I used a piece of 1/2" keysteel [1/2x1/2 square], ground the end down with a slight taper to approx 7/16", so it fitted the plug nicely, then heated and bent the steel 90* so it resembles an allen wrench.
01-12-2020, 01:32 PM | #12 |
01-12-2020, 01:33 PM | #13 |
Good advise, thanks. I still need the length / leverage from the breaker bar. At 85, laying on my back, I need all the assistance I can get from the tool.
01-12-2020, 01:50 PM | #14 |
I have a tool that each end has 4 different size square male protrusions on it and I can always find one that will work, even on plugs that have been messed up and enlarged.
01-12-2020, 02:26 PM | #15 |
Ford put the tool on the end of the adjustable wrench in the tool kit.
01-12-2020, 02:54 PM | #16 |
If I make it to 85, I'm willing to bet I'll still know the difference between 3/8" and 7/16".
01-12-2020, 03:05 PM | #17 |
LOL, what he's saying,guys, is that he needs the length of the 3/8" tool handle to be as long as the 1/2" so he has enough arm strength to loosen the plug.
Terry
01-12-2020, 03:07 PM | #18 | |
I wanna see that 7/16" ratchet! DD |
01-12-2020, 03:20 PM | #19 | |
At times this site just likes to bust chops!
01-12-2020, 04:21 PM | #20 |
000
