Old 10-08-2019, 11:48 AM   #1
Racefanatic5
Default Need help polishing a 1931 grill shell
I'm having a hard time removing the scratches from a 1931 polished stainless steel grill shell. I've used just about every number sand paper up to 1500 grit, still has scratches, does anyone have any idea what i can do? Thanks
Racefanatic5 is offline   Reply With Quote
Old 10-08-2019, 12:04 PM   #2
J Franklin
J Franklin's Avatar
Default Re: Need help polishing a 1931 grill shell
Keep sanding! Or take it to a professional polisher.
Old 10-08-2019, 03:59 PM   #3
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Yeah, if you have noticeable scratches with 1500 grit, then you jumped about two steps in there. Deep scratches should be about gone with 600 grit. Almost all noticeable scratches should be gone by the time you start using 1000 grit. We take all our shells to 3000 grit. It is already starting to have a sheen before we ever put it against the buffer.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 10-08-2019, 05:57 PM   #4
dbaldwi3
dbaldwi3's Avatar
Mine was so bad I had to start at 320, 500,1200, 3000, polishing wheel now it looks like a mirror. Have to admit I was scared hitting it with 320 though! And don’t be in a rush take your time.
dbaldwi3 is offline   Reply With Quote
Old 10-08-2019, 06:05 PM   #5
mike657894
mike657894's Avatar
i used to use mothers have switched to maguires cleaner wax. 2000 3000 they have some in the small strips at home depot. auto body paint shops have high number paper.
mike657894 is offline   Reply With Quote
