Old 04-28-2019, 08:28 PM   #1
hope
hope's Avatar
Unhappy link
Having a problem removing sway bar Link, should be a simple task, but i'm stomped. (40 Ford)
Any suggestions would be very much appreciated.
Thanks.
Hope
hope is offline   Reply With Quote
Old 04-28-2019, 09:25 PM   #2
Sod Buster
Sod Buster's Avatar
Default Re: link
On my 47 I used a big sledge on the backside to back it up, not hit it, then a small hammer to knock it out.
Sod Buster is offline   Reply With Quote
Old 04-29-2019, 06:07 PM   #3
hope
hope's Avatar
Default Re: link
Thanks Sodbuster
But i have already done that, and had to resort to using the torch to heat it up, and with a BFH really wack at it with no result.
Old 04-30-2019, 07:18 AM   #4
Sod Buster
Sod Buster's Avatar
Default Re: link
I would pull the sway bar and go to the vise, some of these parts have been on so long they really have to be solid when you give them a wack to get them apart, might as well replace the two sway bar bushings while your at it.
Old 04-30-2019, 07:43 AM   #5
fordwife
Default Re: link
I use a pickle fork, like is used for tie rod ends.
fordwife is offline   Reply With Quote
Old 04-30-2019, 12:16 PM   #6
hope
hope's Avatar
Default Re: link
Thanks
My next step was that , to remove the sway bar, and good idea to use the pickle fork, will give it a try.
Old 04-30-2019, 09:15 PM   #7
hope
hope's Avatar
Angry Re: link
SHUCKS, the only pickle fork i have is to big ??????????
Will try again tomorrow, to think of something else.
Old 05-01-2019, 02:51 PM   #8
Kube
Kube's Avatar
Default Re: link
There is a special press tool that is made for removing tie rods ends w/o damaging them. Available at any decent auto parts store, I've used one on every 40 sway bar (and tie rod ends) I've ever restored.
Old 05-01-2019, 07:41 PM   #9
hope
hope's Avatar
Default Re: link
Thanks Kube
Got one side free today, after all that struggle it came free, easily (well kind-of).
Will try the other side tomorrow, and if i have too much trouble i'll keep your suggestion in mind.
(slow progress, but its better than noting)
Old 05-02-2019, 10:30 PM   #10
hope
hope's Avatar
Default Re: link
"YYYYAAAHH" Got it done both sides, thanks for the help guys.
Hope
Old 05-02-2019, 10:35 PM   #11
Tinker
Tinker's Avatar
Default Re: link
What'd ya do? pickle fork seems like a decent way and common way for tie rods. so sway bar?
Old 05-03-2019, 08:02 AM   #12
Kube
Kube's Avatar
Default Re: link
Tink,
A pickle fork works on the sway bar swivels. I don't care for a fork in any situation that I plan on reusing the part. They have a tendency to stretch the ball / socket as you surely realize.
Old 05-03-2019, 01:37 PM   #13
hope
hope's Avatar
Default Re: link
The only pickle fork i had, was to big (wide). And i didn't plan on reusing the links, i was replacing them was my goal.
