06-19-2021, 06:09 PM | #1 |
Steering Column Removal 31 Roadster
I want to send my steering column, along with fenders, running boards, and all other "black items" to the paint shop so today I removed it from the car. I know that the proper procedure is to remove the steering wheel and pull the column down and out from the front. However, the steering wheel is stubborn and I was hesitant to apply too much pressure for fear of destroying the wheel or the threads on the shaft so I decided to take the column out from the top. I had to remove the starter and disconnect the brake pedal allowing the pedal to drop forward. After that I was able to pull the column up and out with a bit of a struggle to twist and turn it to clear both pedal arms. I don't think I will be able to reverse this process without doing some damage to the finish on the column after it is painted. Has anybody else done this and would you recommend removing the clutch pedal from the shaft to provide the extra clearance? Is this difficult? Any other suggestions would be appreciated. The painter says he will just cover the steering wheel and paint the column. He doesn't want to risk damaging the wheel either.
06-19-2021, 06:51 PM | #2 |
Re: Steering Column Removal 31 Roadster
https://youtu.be/er3gKmcWZJs
This video will show you how to get the wheel off. |
06-19-2021, 07:59 PM | #3 |
I always remove clutch and brake pedals to get clearance and even then it is a struggle.
I suggest you wrap the column with something like cardboard to protect it from scratching when you are preparing to reinstall it. Kevin |
06-19-2021, 08:27 PM | #4 |
Kevin. Do the pedals come off very easily? Any tricks?
06-19-2021, 10:22 PM | #5 |
top down, pitman arm off, Starter out, both pedals off, column comes right out
06-19-2021, 11:23 PM | #6 |
Kevin |
06-20-2021, 06:28 AM | #7 |
“top down, pitman arm off, Starter out, both pedals off, column comes right out”
12 hours and busted knuckles later......... |
06-20-2021, 08:05 AM | #8 |
No top yet, starter off, pitman arm off, all pluses!. Looks like just remove one pin and pedals and back in she goes! I'll let you know about the busted knuckles. Thanks for the help and encouragement. Took about an hour to take it out but I wasn't worried about scratches. Going back in will be a different story.
06-20-2021, 10:58 AM | #9 |
[QUOTE=fundytides;2028328] I'll let you know about the busted knuckles.[QUOTE]
Here ya go: https://www.bustedknucklerodandtruckmagazine.com/
06-20-2021, 03:56 PM | #10 |
thanks for posting
