Old 05-01-2020, 10:23 AM   #1
johnbuckley
johnbuckley's Avatar
Default Why the roller on top of the float?
Why is there a roller on the top of Zenith floats? ...... ( I know it's useful to change the weight but what the real reason?)
johnbuckley is online now   Reply With Quote
Old 05-01-2020, 01:32 PM   #2
1930 coupe
Default Re: Why the roller on top of the float?
It is a weight, Ford weighed the floats and added weights as needed.
Small variations in weight can make a large change in fuel level.
I have had to add these weights to some reproduction floats to get the fuel level correct.
1930 coupe is offline   Reply With Quote
Old 05-01-2020, 01:53 PM   #3
Will N
Will N's Avatar
What is the correct weight for a float please?
Will N is offline   Reply With Quote
Old 05-01-2020, 02:18 PM   #4
1930 coupe
31 grams plus or minus 1/2 gram
Old 05-01-2020, 02:19 PM   #5
alexiskai
alexiskai's Avatar
31.4-31.8g
http://www.fordgarage.com/pages/ZenithAfloats.htm
Old 05-03-2020, 09:55 AM   #6
Will N
Will N's Avatar
Thanks you!
Old 05-03-2020, 02:43 PM   #7
johnbuckley
Smile Re: Why the roller on top of the float?
yes, Ford Garage http://www.fordgarage.com/pages/ZenithAfloats.htm is an interesting page on floats. But it's not just weight that counts .... fuel level in the bowl will also be changed by the float dimensions being different ( a slightly wider float (displacing more fluid) - and they are not all absolutely accurate dimensions -will float higher , sealing the valve at a lower fuel level). Also the head of fuel difference between full and empty tank will change the bowl fuel level - small print I know...I'm sure dear Archimededs didn't realise we'd still be thinking about him 2000 years on.
