Old 02-13-2020, 03:08 PM   #1
marshall k
Default 1952 f7 brake booster
Greetings : Trying to help another party find a brake booster for his 1952 f7. Found an oem number we think is correct: 7EQ 2005 b. Any info out there relating to re-builders or after-market producers of this booster? Thanks for your time!
marshall k is offline   Reply With Quote
Old 02-13-2020, 05:12 PM   #2
Bob C
Default Re: 1952 f7 brake booster
Does he have one that need rebuilding or missing one? The rebuild kit is A8Q-2309-A.
I looked on Parts Voice and they show a kit at http://www.greensalescompany.com/
Bob
Old 02-13-2020, 07:46 PM   #3
rotorwrench
rotorwrench's Avatar
The early big jobs may have used several types of brake booster. The Ford part number may be a clue but a person needs more information. Hydro-Vac was one of the more popular but they made a lot of different models. If a person knew what manufacture they used it would be a big help. I know Ford used Bendix and Midland as well as a few others back in the day. There are a few big job owners that frequent here and over on the Ford Truck forum. This outfit may be able to help.
https://brakematerialsandparts.webs....otoid=77364701
Old 02-14-2020, 05:10 AM   #4
big job
big job's Avatar
I have a 1964 Trojan loader the master cylinder and the booster is exactly the same as
the F7 Napa I had both the next day - if this helps. The booster was around $185 new, not rebuilt same as the master cylinder. Always bring your parts with you. sam
big job is offline   Reply With Quote
Old 02-14-2020, 08:34 AM   #5
marshall k
It is a Bendix- I will pass this info on to the owner. Thanks!
Old 02-14-2020, 08:59 AM   #6
big job
big job's Avatar
Marshall, keep in mind any Midland , Bendix , hydrovac does the same thing.
So you make another bracket mount, so what, it will work.
I am gifted; I hate despicable juice brakes all mine are air!!
Old 02-14-2020, 09:14 AM   #7
big job
big job's Avatar
Like this F8 (no rust 337cic 5 +2 ) nope pictures don't work no more..ugg
