Old 04-27-2011, 09:15 PM   #1
1928Pickuppain
1928Pickuppain's Avatar
Default light rod stuck in shaft
so i picked up a steering shaft and worm gear this past weekend and rebuilt my steering box on my 7 tooth and installed it then i was told there might be a chance that the old light rod may be stuck in it well i came home from work today and looked it shere is how on earth am i going to get this out without removeing my collum again
1928Pickuppain is offline   Reply With Quote
Old 04-27-2011, 09:29 PM   #2
Keith True
Keith True's Avatar
Default Re: light rod stuck in shaft
Pick an old drill bit that will just fit in the bore,braze a rod to it and start twisting.At some point it will bite in,and the remains of the shaft will start to twist.I never gave it a thought until you started asking about light switch rods.I thought I had stripped it out,but it has been sitting there for ten years so I really couldn't remember.
Keith True is offline   Reply With Quote
Old 04-28-2011, 07:53 AM   #3
banjobrad
I bought a reproduction light rod that was about .005" too large for the shaft center hole. Had to do a lot of sanding to make it fit. Not sure if anyone else has experienced this little anoyance.
B.G.
banjobrad is offline   Reply With Quote
Old 04-28-2011, 08:48 AM   #4
Ray in La Mesa
A fellow in our club has the same problem of to large a repro rod, plus, someone peened over the steering shaft trying to get the wheel off. He has a lot of filing to do. Make sure you include the little brass collar at the top of the horn rod.
Ray in La Mesa is offline   Reply With Quote
Old 04-28-2011, 11:20 AM   #5
1928Pickuppain
im thinking about trying to get a rod thats the same size and pownd it out though the bottom.
Old 04-28-2011, 01:02 PM   #6
banjobrad
Not sure what the actual size of a steel dowel is, I think the shaft hole dia. is
.370", but a dowel might be about the same size. If you make sure there are no burrs and use a good penetrating oil you might be able to push it through with a little hammering. Good luck on that one.
B.G.
Old 09-24-2020, 05:09 PM   #7
banjobrad
Had to sand mine down, took a while.
Old 09-25-2020, 07:25 AM   #8
ryanheacox
ryanheacox's Avatar
I think the size of the repro rods has been addressed. I just got one from Snyders and measured it against the old original and they were within .001 of each other. Original was .373, new was .374. Slipped right into the steering shaft along with the small bushing.
The only thing the new rod needed work on was deepening the groove for the spider keeper, other than that the fit and finish seems pretty nice.
ryanheacox is offline   Reply With Quote
Old 09-25-2020, 10:53 AM   #9
Brentwood Bob
Rust in the bore would complicate removal.
Brentwood Bob is offline   Reply With Quote
Old 09-26-2020, 05:34 PM   #10
redmodelt
redmodelt's Avatar
Being that the horn rod is hollow, you might have good a chance of crushing/mushrooming it out, getting really stuck and not moving it at all just using a steel rod and hammer to drive it out. Or it will just pop out the end. You can try.
Old 09-26-2020, 09:02 PM   #11
Purdy Swoft
Purdy Swoft's Avatar
I had to drill one out but it worked . I did similar to what Keith True did in post number two .
