Old 09-25-2020, 01:57 PM   #1
harleycontracter
Default Throttle control Lever question
When I pull down on my throttle control lever I feel a bit of resistance. If I pull down on it it returns part way. Someone said could be springs at the bottom of the column ????
harleycontracter is offline   Reply With Quote
Old 09-25-2020, 02:31 PM   #2
Brentwood Bob
Default Re: Throttle control Lever question
When the motor is pulled and also when reinstalled the throttle assembly can get bumped, or mangled. Also rarely does the shaft get any oil.
Brentwood Bob is offline   Reply With Quote
Old 09-25-2020, 02:49 PM   #3
Big hammer
I've seen people that have added a throttle return springs from the carburetor to firewall.
get a bigger hammer tap done
Old 09-25-2020, 04:37 PM   #4
Bob C
Here's a link to quadrant repair. https://www.fordbarn.com/forum/showt...uadrant+repair
