Old 08-07-2020, 12:45 PM   #1
19Fordy
19Fordy's Avatar
Default Banjo Gear oil Question.
I would appreciate it if a Fordbarner would give an explanation of what the little passageway on the end of the torque tube is for and how it functions.
I think it's related to rear gear oil flow.
You can see the upside down "U" Shaped passageway in the upper right of center in the photo.
Thank you. JIM
Old 08-07-2020, 01:05 PM   #2
petehoovie
petehoovie's Avatar
Default Re: Banjo Gear oil Question.
Thank you. JIM
The only thing nice about being imperfect is the joy it brings to others....
"Silver rings, your butt! Them's washers!"
"We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969
https://www.youtube.com/watch?v=7NReUd2_0u0
Old 08-07-2020, 01:27 PM   #3
Will D
Will D's Avatar
From what I gather it should be installed on the bottom and allows the gear oil to return to the diff when it passes thru the pinion double bearings.
Will D is offline   Reply With Quote
Old 08-07-2020, 03:26 PM   #4
Rodrelic
I understood the passage has to be kept open, gasket also aligned, to provide run-back of oil as well as venting up torque tube so wheel seals will not leak.
Rodrelic is offline   Reply With Quote
Old 08-07-2020, 05:16 PM   #5
19Fordy
19Fordy's Avatar
Thank you Rodrelic , Pete and Will for answering my question.
Old 08-07-2020, 07:07 PM   #6
JSeery
JSeery's Avatar
Most rear axles have a vent built into them, the original Ford banjos got away without one because of the volume of air between the axle itself and the torque tube. One of the things that is often done with a quick change modification is the addition of a vent on the axle housing. Gears turning and heat can generate a lot of pressure and this pressure will tend to force the gear lube past the seals, thus the need for vents. But again, Ford relied on the volume of air in the torque tube to buffer the pressure in the axle housing.
Old 08-07-2020, 08:13 PM   #7
19Fordy
19Fordy's Avatar
Mr. Seery, Thanks for adding that tid bit of helpful knowledge.
Old 08-08-2020, 09:23 AM   #8
Planojc
Planojc's Avatar
Also if you install a Mitchell overdrive, you should vent the axle due to much shorter torque tube between the banjo and the Mitchell gearbox.
Planojc is offline   Reply With Quote
