06-10-2020, 12:59 PM | #1 |
Replacing Floor pan and rocker panel 52 Ford F1
I need to replace the passengers side front floor pan and rocker panel on my 52 Ford F1. What sequence of replacement is best? Any tips on how to replace these items?
06-10-2020, 01:47 PM | #2 |
Re: Replacing Floor pan and rocker panel 52 Ford F1
Is can still mounted on chassis
06-10-2020, 01:51 PM | #3 |
no its off the chassis
06-10-2020, 02:34 PM | #4 |
Do floor first leaving rocker to hold door opening correct & then rocker is how I did mine. Worked out great.
06-10-2020, 04:19 PM | #5 |
brace it from front to back leaving the door on to get your gap then remove it for ease of working the corners I did a 51 that someone didn't brace wound up cutting the jamb on the back edge the cab was finished on the inside lots of work
06-10-2020, 07:00 PM | #6 |
06-10-2020, 10:33 PM | #7 |
From what I've seen and heard, expect to need to do some metalworking to make the new piece work. Saw one that was 1/2" different where it joined the firewall section.
'52 F-1, EAB flathead |
