Old 05-03-2020, 01:44 PM   #1
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
Default Ignition Volt Drop
trying something new here , this is from a class i taught for years and its in Gmail slides etc . trying to bring picture or slide here for discussion
Here goes
https://docs.google.com/presentation...9efccc7ef_1_98
Looks like it will work and you can move around in the program , play with it a little and i will add some discussion as time allows .......
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 05-03-2020, 01:59 PM   #2
51woodie
51woodie's Avatar
Default Re: Ignition Volt Drop
Looks like you need to create a Goggle account to view.
51woodie is offline   Reply With Quote
Old 05-03-2020, 02:22 PM   #3
BUBBAS IGNITION
i changed the access with a email for a few just then let me know how i can help OR if anyone is getting the files ........
[email protected]
Old 05-03-2020, 02:23 PM   #4
BUBBAS IGNITION
https://docs.google.com/presentation...it?usp=sharing try this link
[email protected]
Old 05-03-2020, 02:34 PM   #5
Zeke3
Zeke3's Avatar
I can see it with either link. I do have a gmail account also, if that matters.
Zeke3 is offline   Reply With Quote
Old 05-03-2020, 06:16 PM   #6
JSeery
JSeery's Avatar
Nice, Bubba! Three of the slides were blank, but assume that is because it is a work in progress.
Old 05-03-2020, 06:23 PM   #7
Anteek29
Anteek29's Avatar
It works
Alan
1929 Special Coupe
1941 Pick-Up
1955 Victoria
Anteek29 is offline   Reply With Quote
Old 05-03-2020, 06:41 PM   #8
Heard
Heard's Avatar
Jim, that is pretty neat! Works for me.
Do I look like I have a plan B?
Heard is offline   Reply With Quote
Old 05-04-2020, 03:23 AM   #9
fortyonerag
fortyonerag's Avatar
Works here.
fortyonerag is offline   Reply With Quote
Old 05-04-2020, 07:45 AM   #10
BUBBAS IGNITION
Ok lets start by reading the notes under slide three ( 3 ) then think of this slide as the ignition in your car .
Series circuit , constant current and voltage drop in the system . Hopefully designed to run and last a long time .
Then move on to slide 4 showing the ignition components .
Questions ???
[email protected]
Old 05-04-2020, 09:18 AM   #11
JSeery
JSeery's Avatar
Originally Posted by BUBBAS IGNITION View Post
Questions ???
Slides 10, 12 & 13 are blank, are those "coming soon" place holders?
Old 05-04-2020, 09:54 AM   #12
BUBBAS IGNITION
No just a empty space for the class i deleted them on the master slide program..
[email protected]
