Old 08-16-2020, 02:53 PM   #1
37 Coupe
37 Coupe's Avatar
Default Close call today fuel everywhere.
I let attention lapse on my '37 Ford coupe last year or so and thought it would just be its old reliable self and it seemed to at first.Started right up but rough running ,smelled gas and it was everywhere over generator with its paint peeling off,all over firewall,heads ,battery,very lucky it did not catch fire before I discovered.At first I thought fuel pump or a fuel host to pump split but must have been a stuck float? if fuel pump kept pumping fuel everywhere.Guess I will find out this week when I get time. This was a lot of gas all over garage floor,thought it was coolant when I backed it out.I feekl very fortunate.
"Never complain,never explain"... Henry Ford II
37 Coupe is offline   Reply With Quote
Old 08-16-2020, 02:59 PM   #2
19Fordy
19Fordy's Avatar
Default Re: Close call today fuel everywhere.
Thank goodness nothing really, really bad happened. Fire extinguisher handy?
Old 08-16-2020, 03:00 PM   #3
JSeery
JSeery's Avatar
That could have turned out bad!
Old 08-16-2020, 03:06 PM   #4
fourtydlx
fourtydlx's Avatar
Send a message via Yahoo to fourtydlx
lucky you
fourtydlx is offline   Reply With Quote
Old 08-16-2020, 03:14 PM   #5
deuce_roadster
deuce_roadster's Avatar
Boy I sure am glad luck was with you. My guess it is either junk kept the needle valve from shutting off the fuel or the old float finally sprung a leak and sunk.
Old 08-16-2020, 03:32 PM   #6
oldskool
oldskool's Avatar
if you have a stromberg carb it best to change to a grose valve instead of the needle and seat type
oldskool is offline   Reply With Quote
Old 08-16-2020, 03:35 PM   #7
37 Coupe
37 Coupe's Avatar
It is a Stromberg 97 but one of the new ones .I bought it years ago from Uncle Max.I don't know if he is still on Fordbarn.I would say it has run good for 12 years or so.Time sure flies.
Old 08-16-2020, 07:42 PM   #8
leon bee
That's a mighty good reminder to check the extinguishers in all my old heaps.
leon bee is offline   Reply With Quote
Old 08-16-2020, 07:50 PM   #9
petehoovie
petehoovie's Avatar
Electric fuel pump?
Old 08-16-2020, 08:29 PM   #10
uncle max
uncle max's Avatar
If it's the float - and from what you've said it just might be - I will still WARRANTY it. Quite possibly the best warranty on the planet. Just let me know...
RIP Tyler... My Son, Helper & Best Friend.
Feb '78 to Father's Day '10.
www.97-express.com ~ [email protected]
uncle max is offline   Reply With Quote
Old 08-16-2020, 09:24 PM   #11
V8COOPMAN
V8COOPMAN's Avatar
Originally Posted by uncle max View Post
If it's the float - and from what you've it just might be - I will still WARRANTY it. Quite possibly the best warranty on the planet. Just let me know...
Man, are there some GOOD folks here, or what? There's hope for America yet! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 08-16-2020, 09:33 PM   #12
JM 35 Sedan
JM 35 Sedan's Avatar
....and quite possibly one of the best Stromberg carburetor re-builders on the planet.....
John
Old 08-17-2020, 07:22 AM   #13
37 Coupe
37 Coupe's Avatar
Oh yea and quite frankly I am glad to see he is still on Fordbarn and still at it. I think his profile he used to use showed he is about 130 years old by now.
Old 08-17-2020, 08:19 AM   #14
37 Coupe
37 Coupe's Avatar
Electric fuel pump?
Not an electric fuel pump.
Old 08-17-2020, 09:22 AM   #15
uncle max
uncle max's Avatar
130 year old central nervous system in a 75 year old body, to be exact.
