Old 05-19-2020, 09:57 AM   #1
pjdeb
pjdeb's Avatar
Default Hub Production History
Pulled the rear wheel hubs today. Found that the are different. Someone must have replaced on somewhere along the line.
One side has 1/2" groove. Perfect for the red flanges on a Mitchell puller.
The other has a groove slightly smaller that 3/8." I had to grind the faces of the smaller black flanges. Highly recommend the Mitchell puller.....two sets of flanges, solid construction, large hammer/bump spot.
Anyone know the history of the hubs used? Changes from 28 thru 31?
pjdeb is offline   Reply With Quote
Old 05-19-2020, 11:36 AM   #2
Tom Endy
Tom Endy's Avatar
Default Re: Hub Production History
See attached article.
Tom Endy
Old 05-19-2020, 05:32 PM   #3
Synchro909
Synchro909's Avatar
I have one of those pullers with two halves and a sleeve that goes over then. It fits the groove type hub but not the shoulder one and one of my cars has one of each so when I need to remove the hub, I'll be in trouble.
Does anybody have a more detailed diagram of the Mitchell puller please. They say it will do any of the hub designs so I think that might be my savior so long as they are strong enough. Are they?
Old 05-19-2020, 07:39 PM   #4
160B
160B's Avatar
Originally Posted by Synchro909 View Post
............................Does anybody have a more detailed diagram of the Mitchell puller please. They say it will do any of the hub designs so I think that might be my savior so long as they are strong enough. Are they?
Synchro,
In post #2 the attached file is the Mitchell drum puller. The problem is the text refers to green and black components and they are all black.
1931 160B & 1931 68B
If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time?
160B is offline   Reply With Quote
