02-14-2018, 04:13 PM | #21 |
Re: 1930 Brakes
Curtis I am going to have to study that subject Pills, to properly understand the movement there. That could explain why the Brake adj wedge was all the way in at the 15% arm position and no brakes. Seems like the best place to start. does it sound like I need more Pills?
02-14-2018, 04:35 PM | #22 |
Re: 1930 Brakes
Ron, I am far from being an expert but just finished a complete rebuild on the brakes on my 30 coupe. I did replace everything on all four wheels, and after the rebuild I have excellent brakes. One thing that I did that I did not see mentioned above, unless I missed it, was to adjust the clevises on the ends of the brake rods on all four wheels, so the pin will just slips in when the slack is pulled out of the actuating arm. This allows all four brakes, when adjusted correctly, to be applied evenly. Good luck
02-14-2018, 05:37 PM | #23 | |
Re: 1930 Brakes
02-14-2018, 08:15 PM | #24 |
Re: 1930 Brakes
Andrews discusses pills (shims) on p. 1-39 of the red book.
02-14-2018, 08:32 PM | #25 |
Re: 1930 Brakes
Start by putting the same linings on the front, and the same style on the rear, instead of 4 on one side and 4 on the other side. Woven grip better, so the car will pull to the side with woven linings as they are now set up.
Go by the brake adjustment procedure in the SERVICE BULLETINS, and you should have good brakes if the parts aren't worn out. Where are you located? |
02-14-2018, 08:44 PM | #26 |
Re: 1930 Brakes
tracks been rebuilt, have the brake shoes been centered?? Bob |
02-14-2018, 09:19 PM | #27 |
Re: 1930 Brakes
In his first post he says he's in Italy.
02-14-2018, 11:24 PM | #28 |
Re: 1930 Brakes
Do a ford barn search for brake adjustment and setup .I have posted this operation dozens of times .
02-15-2018, 01:16 AM | #29 |
Re: 1930 Breaks
According to the Service Bulletins, page 514, "Under no circumstances must any attempts be made to turn down brake drums..." Maybe that is why you don't see any numbers for steel drums.
02-15-2018, 01:35 AM | #30 |
Re: 1930 Brakes
Ron, please do not confuse “replaced”with “rebuilt”. Simply replacing parts in the brake system does not necessarily make the system effective, nor rebuilt. It is a complex mechanical problem, and takes very thorough work to make the brake system truly “rebuilt” and safe. It can be done, and is usually within the scope of the abilities for most owners. Just make sure everything is fit tight and correctly.
02-15-2018, 12:31 PM | #31 |
Re: 1930 Brakes
T B lots of slack in the right actuating arm front. To remove all the slack makes the arm straight up and down, however the book calls for 15%. Any comment please anyone..
02-15-2018, 12:42 PM | #32 |
Re: 1930 Brakes
Have you read Andrews’s chapter on brakes in his red book yet? You said you had it, I believe. Many of your questions are addressed there, along with step by step instructions.
Ray Horton, Portland, OR As you go through life, keep your eye on the donut, not the hole. Last edited by 700rpm; 02-15-2018 at 12:59 PM. |
02-15-2018, 01:21 PM | #33 | |
Re: 1930 Brakes
If the rods are worn down, then I'd buy new ones. That's all it took to make my levers slant forward at 15*. 1 or 2 pills in the wedge can also make the lever slant forward. |
02-16-2018, 04:26 PM | #34 |
Re: 1930 Brakes
I can see from all the assistance that I got, that I just have to pull all parts and check, Check and Check again. I had less sponge action after adjusting the acuating Bar on the front. Brakes stop better, but there is still that moment of sponge feeling and I think it will new resolved with centering of the breaks, at least checking this condition and Operating Pin needs Pills. Thanks to everyone who responded to my need. Now I will get to work in the Les Andrews book and examining all issues. Hope I have the ability to understand this hobby. Sure would not like to let this thing beat me.
thanks again. |
02-16-2018, 06:00 PM | #35 |
Re: 1930 Brakes
You’ll be fine. Read the books suggested, go slowly, ask questions about parts you don’t understand. Thousands of us, maybe all of us, have been right where you are now. The Model A is very simple, but don’t think that means it does not require careful work.
02-16-2018, 06:25 PM | #36 | |
Re: 1930 Brakes
Once your worn part problems are taken care of. The adjusting will seem easy. No short cuts, check everything. These cars were made to be serviced by there owners. 90 years of use, Henry had it right. Enjoy. |
02-17-2018, 04:44 PM | #37 |
Re: 1930 Brakes
If all else fails, send everything to Randy Gross. You will get back what looks like factory new. Still need to have everything else up to snuff though.
02-17-2018, 06:24 PM | #38 |
Re: 1930 Brakes
Ron- Did you replace the drums? The new cast iron drums are much better than the old steel drums. Also another thing to check is your brake rods. bent rods will cause spongy brakes. Don't ask how I know this.
02-17-2018, 07:28 PM | #39 |
Re: 1930 Brakes
Are your brake rods STRAIGHT?
02-17-2018, 08:31 PM | #40 |
Re: 1930 Brakes
Yes- are your break rods straight? I had one with a slight bend in it. ( don't know how it got bent) however I adjusted the brakes with the bent rod and didn't notice it until checking the poor braking. the rod would straighten out as the pedal was pressed. This limited the amount of pressure to the shoes.
