06-26-2020, 03:43 PM | #1 |
Hinge bolt removal
Best way to remove slotted head Hinge screws in 29 roadster
Jimmy Palmer |
06-26-2020, 04:29 PM | #2 |
Re: Hinge bolt removal
For tight screws in general the best tool that I have found is the hand held impact driver with a driver bit to CORRECTLY fit the screw head. This tool imparts a loosening torque and linear force simultaneously.
Joe B |
06-26-2020, 04:52 PM | #3 |
I agree! An impact driver is often an overlooked tool.
06-26-2020, 05:41 PM | #4 |
Are you speaking of a removal that is trying to maintain paint etc
Or, will you be repainting etc? If the former, heat and kroil will do wonders |
07-07-2020, 09:34 PM | #5 |
I got it with the impact tool and lot of soaking
Jimmy Palmer |
07-08-2020, 10:19 AM | #6 |
07-08-2020, 08:36 AM | #7 |
Used a square shank screwdriver with a crescent wrench..went back together with never seize on the threads.
07-08-2020, 09:08 AM | #8 |
I usually need to heat them red hot first .
